bzxfire40
- Nov 30, 2016
Does anyone know of anyway to get the ZX2 to act as a USB DAC thru a PC?
Under settings, sound, eq. I turn up the clear bass and use the eq. On my ZX2 it affects everything, including Tidal. I bought my ZX2 used off a fellow head-fier. I wonder if it's hacked. It never ran fast. I have an old Xperia phone (Z3 compact) and its eq doesn't affect tidal.
Received my first TRRS cable today, for ZX2 / OPPO PM3's. After a couple of hours listening, i'm very impressed. Sounds really clean, with no hint of distortion. ( If that's the right description ! ? )
Any cables with 4 internal wires can be made to TRRS.Where did you get the TRRS cable from? I've been looking for one but unable to find (I'm in the UK) for the PM3.. Does it change the tonality - is it brighter/warmer would you say going balanced?
If use a 3.5mm TRRS extender with a TRS plug will this allow me to take advantage of the balanced out on the ZX2?
This is the extender:
https://www.amazon.com/gp/aw/d/B016...r+3.5+trrs&dpPl=1&dpID=31Csabye6lL&ref=plSrch
Oops my bad. Not true balanced output but isn't using a cable with a TRRS plug supposed to improve stereo seperation since the jack on the ZX2 is also TRRS?
Yes, you can use the TRRS on the ZX2 but for that you'll need a cable that has 4 wires correctly wired to the TRRS 4 poles.
Technically speaking, this is a balanced cable.
If it is terminated with a 2.5mm balanced connector, you'll need an adapter to the 3.5mm.
Nope, that won't work, you need to get a custom balanced cable terminated to 3.5 trrs and take care to mention that you need it for zx2, because other daps might use different cables.
