SONY NW-ZX2 DAP
post-13816086
Post #13,981 of 14,547
proedros
Athens , Greece
Athens , Greece
find and buy a non-EU zx2 without the volume limiter , it's not worth it
i had the EU version , then sold it and got the Japan version - and my piece of advice is this : just go for a non-EU model
cheers
post-13816407
Post #13,984 of 14,547
riotgrrl
I must have missed that.
So, it will not be 20-30% louder as stated in the post?
The vague 20-30% is the whole point here. Someone claimed to have eeked out an unproved percentage difference. Anyone with both units can tell the volume cap is significantly louder than that. So whatever it changes, if indeed it changes anything at all, it sure ain't the volume cap.
As with the newer Sony models, where the volume cap can definitely be removed, if this solved the problem then owners would be all over it.
Reactions: proedros
post-13818907
Post #13,985 of 14,547
Sinarca
I'm looking for Sony WMC-NWH10 digital cable.
If someone want to sell, PM me
I'm in Italy, and buying it from Japan = shipping time too long
post-13830243
Post #13,987 of 14,547
Richter Di
Germany
Germany
Age
54
Website
pilates-powers.de
Hi, I am looking for a system wide EQ with Convolution filter for the Sony NW-ZX2. I like to use it with the Audzee iSine 20 and the WAV file with the convolution is so far the closest I could get to the Cipher cable. Any recommendations?
post-13831343
Post #13,988 of 14,547
asquare3376
Wayne, New Jersey
Wayne, New Jersey
Hello friends,
need to ask a quick question, the answer to which I know is buried somewhere in this thread.
How can you charge the PHA-3 and play it simultaneously? What charger and how many amps? I was looking at Sony's AC-UD20.. Can this charger do the trick?
post-13844781
Post #13,989 of 14,547
AlexZK
London
London
Quick question from someone considering picking up a second-hand ZX2 - how is the battery faring after 1 or 2 years of use for you guys?
post-13845157
Post #13,990 of 14,547
wirefriend
The battery is one of the strongest points of ZX2. It was something around 6h in my old one when played. 2-3 days if not used.
Reactions: AlexZK
post-13845176
Post #13,991 of 14,547
Domdom
Mine is not what it used to be BUT still very fine compared to any smartphone. Just dont forget to activate plane mode when not using it!
Reactions: AlexZK
post-13866412
Post #13,993 of 14,547
Sinarca
Hi, I have just connected my ZX2 to my DAC with Sony WMC-NWH10 USB conversion cable, but....No sound...Am I missing something ?
post-13866425
Post #13,994 of 14,547
Whitigir
Hello friends,
Pha-3 has separated charging circuitry which uses Micro USB, and can be charged simultaneously by IPad Pro Charger
I never used AC-UD20 because there was never any need for it. Using iPad Pro Charger I was able to get the Pha-3 to always be remained at full battery, and operating 24/7
post-13866426
Post #13,995 of 14,547
Whitigir
You may be missing something. I had never failed to use this NwH10 Dongle Cables to do digital output into external DAC. Could be your usb cables that you connected it to. Swap the cables and see ? Did your DAC input opted for USB connection ?
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
