SONY NW-ZX2 DAP
post-13333317
Post #13,771 of 14,547
NoMythsAudio
Miami
Miami
5 posts back. 4.4 is only for the new WM1 players. I can't answer your question about wich ground goes where as I don't know
4.4 mm is also available on the new Sony PHA-2A dac/amplifier.
post-13338281
Post #13,772 of 14,547
chancee
Thanks for the responses about Tidal.  I'm having a tough time trying to decide whether to get the WM1A or ZX2... I think not being able to stream Tidal or anything else would be a big blow.  I've spent a couple weeks reading through the WM1A thread and other than obvious hype from people having just bought the WM1A, many of the reviews are mixed and don't say the WM1A's sound quality is necessarily far and away better.  Some actually saythe WM1A is a bit more clinical and on the dry side.
I'll be using campfire jupiter's, Lyra 2, and maybe my fostex th-900's, which I actually listen to out of my iphone 6 sometimes and they still sound great..  I guess LCD-2's would be a no go though.
post-13343988
Post #13,773 of 14,547
Gosod
Europe!
Europe!
I think that you like, Zx2 more-than-WM1a, it's just more money in it the sound is not different from the Zx2 too much.
post-13348174
Post #13,775 of 14,547
Duncan
Moderator
post-13348333
Post #13,776 of 14,547
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
it's 3.5 to 3.5
2.5 is for AK players
He probably have a headphone cable terminated for AK balanced and want ti use it with Sony
post-13348626
Post #13,778 of 14,547
mathi8vadhanan
post-13351118
Post #13,781 of 14,547
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
post-13352678
Post #13,782 of 14,547
TooFrank
I haven' used a card for Tidal :wink:storage but maybe it is not allowed because Tidal don't want you to be able to take the card out for potentially to use it on another device. Saving Tidal stuff on internal memory works like a charm..:wink: I
post-13364154
Post #13,783 of 14,547
chancee
Does anyone know if you can adjust the volume on the ZX2 to lean more towards the left or the right?  I would like it to be just a little louder on the right side.  Thanks
post-13364233
Post #13,784 of 14,547
rookie2009
I don't believe it's possible with the stock player to adjust left/right balance,but you can do this with Gonemad player if you download it from the play store.. :)
post-13364265
Post #13,785 of 14,547
highfidelity69
I suggest you go see a doctor to check your hearing, you might be doing irreparable damage to your hearing, a small break in head gear might help, also tone down the volume if you can't do what I recommended. It is also natural to hear a little better from each ear, same goes for your vision, one eye is always a bit stronger than the other.
