SONY NW-ZX2 DAP
Discussion in 'Portable Source Gear' started by leylandi, Nov 16, 2014.
908 909 910 911 912 913 914 915 916 917
919 920 921 922 923 924 925 926 927 928
  1. AUDIOBREEDER
    will trrs to 4.4mm still come out balanced on the ZX2?
  2. nc8000 Contributor
    ZX2 does not support 4.4 and ZX2 is seperate ground not balanced but you will get seperate ground from ZX2 with a 3.5 trrs male to 4.4 trrrs female if that is what you mean
  3. Richter Di
    Could one of you confirm that this is how the TRRS is wired with the ZX2:
    Sleeve: R-
    Ring 2: L-
    Ring 1: R+
    Tip:       L+
    Many thanks!
  4. nc8000 Contributor
    And the 4.4
  5. Richter Di
    Hi, thanks for the quick answer, but you lost me.
    I know the Sony picture, but this does not say if ring 3 or ring 4 are R- or L-.
    And the 4.4 I did not understand at all. Does the ZX2 also accept this? If yes, I must have missed it.
    Anyhow, I bought 5 TRRS plugs and asked a friend to change them for me. So I realy need to make sure if this is correct:
    Sleeve: R-
    Ring 2: L-
    Ring 1: R+
    Tip: L+
    Many thanks!
  6. gerelmx1986
    He said already ZX2 does not do 4.4
  7. Richter Di
    Where?
    Is there not possibly an easy yes or no to my question?
  8. nc8000 Contributor
    5 posts back. 4.4 is only for the new WM1 players. I can't answer your question about wich ground goes where as I don't know
  9. ttt123
    The ZX2 TRRS is the same as the HifiMan HM-801, and the re-zero Balanced Plug below.
    Note: The cable's foil or braided shield must NOT be connected to anything at the TRRS plug end of the cable.[​IMG]
    [​IMG]
    Richter Di likes this.
  10. nc8000 Contributor
    I knew I had seen those diagrams before but could not find them
  11. chancee
    Can you still stream Tidal on the ZX2?  I'm thinking of getting one but I read somewhere that the android version was so old that Tidal wouldn't work anymore.  Is that true?  If it isn't true, does it seem like something that could happen in the next year or so?  I wouldn't want to shell out $1200 only to not be able to download from Tidal in a year.  Thanks!
  12. ccklone
    Hey Now,
    I stream Tidal everyday at work on my ZX2.
    Finest kind,
    Chris
  13. nc8000 Contributor
    It works fine now but I think it is a real concern that it might stop working at some point but nobody can tell you for sure
  14. Gosod
  15. Richter Di
    Yes, no problem. Qobuz unfortunately crashes too often.
