SONY NW-ZX2
Oct 1, 2016 at 10:48 AM Post #13,201 of 14,755
That depends on what phones you want to try it on and how they are cabeled
ok so i need an IEM that i can then recable ..i have a cheap chinese **** 4in1 coming i dont know how it sounds but i might use that for the recabling
Oct 1, 2016 at 11:01 AM Post #13,202 of 14,755
The essential part is that you need a cable with 4 wires all the way to the plug from the drivers (2 from each driver).
Oct 1, 2016 at 3:49 PM Post #13,205 of 14,755
I think I found a way to maximize the zx2's performance......
I read this sound enhancement guide on the thread but was wondering if you tried the following. I found the zx2 to sound very different under 3 conditions.
1 is with the sound enhancements on and off of course
2 is your way with turning sound enhancement off on the settings->app->under all.
3rd one I found out today is enabling sound enhancements then disabling the sound enhancements......then going to settings -> apps -> and going to running tab and not the all tab.....and kill the sound enhancement track on the running tab. It should be 5 megabytes or so. Then restart the same track.
3rd option i found makes the ZX2 absolutely 100% neutral signature.....compared to the warm sound you get from completely disabling the 20.0k app in all and getting this mushy sound that is dark with recessed lower treble and super strong bass....detailing is much better and there is much more energy in the sound that people complained about. IMO it sounds much better. Try this guys and let me know. I can definitely hear the difference with my studio monitors here for sure.
Oct 1, 2016 at 4:10 PM Post #13,206 of 14,755
Could you explain your third step in more detail? I'm intrigued and may give it a go this evening
Oct 1, 2016 at 4:19 PM Post #13,207 of 14,755
Turn on your zx2. Open Sound Enhancement app. Check Clearaudio+ then Uncheck it. Press app drawer icon bottom right corner. Swipe it to close it. Its still running in the background though. So you go to Settings-> Apps.....then go to the third tab labeled running.....not the last one labeled all. Stop the Sound Adjustment app....it'll ask you....do you want to close it. It might make other apps stop working.....click yes. Now listen to your music in your music player. It'll be totally neutral and amazing!
If you want to hear the difference, then while playing the song....lower the volume......and go to Settings->Apps go to the last tab labeled all and stop the Sound adjustment app. The volume will spike and the sound will change. bass will be overpowering and the lower treble will be recessed. It is night and day difference with vocals. Let me know your experience.
Oct 1, 2016 at 4:34 PM Post #13,209 of 14,755
[COLOR=111111]someone can suggest an app that can make the sound player louder?[/COLOR]
No such thing to my knowledge
Oct 1, 2016 at 6:10 PM Post #13,212 of 14,755
After the unveiling of the 1A and 1Z and much hemming and hawing, I have decided to stick with the ZX2 for now. I'm honestly not interested in chasing additional, hypothetical increases in sound quality. Rather, I'm more interested in an all-around DAP. And the 1A and 1Z eschew a lot of features which I value. Similarly, a lot of competitors don't QUITE seem to have their act together in regards to building a solid, stable Android implementation, or have poor support for media management, or have poor battery life, etc.
So to celebrate my decision (or rather as a way of forcing me to stand by my decision and not be swayed by a seductive competitor), I decided to sink some cash into a new case for the ZX2—from Dignis.
I had the white/beige one previously and did not like it at all. The leather itself was thin, and cardboard-y, had a poor texture and an ugly color in most light, frankly. I decided to get the red one this time. I figure, in the world of high-end DAPs, why settle for pedestrian colors? The more ostentatious, the better. Much like exotic super cars. Sure you could get a Ferrari in black or silver. But they really look best in "Arrest Me" Red.
And I can say the leather on this version is much more appealing compared to the white/beige.
Oct 1, 2016 at 6:34 PM Post #13,213 of 14,755
damn i want one too :frowning2:
Oct 1, 2016 at 9:54 PM Post #13,214 of 14,755
Wow... looks good!
Holding back on the Dignis as it seems that it does not protect the bottom part? Using the Cruzerlite (also has a igadgetz) silicon case as it protects all the corners and edges including the bottom part. But really like the premium leather of Dignis though.....
