SONY NW-ZX2 DAP
post-12263948
Post #10,186 of 14,485
proedros
Athens , Greece
Athens , Greece
so , what happens when the trial period for the alpha version of poweramp ends , do we just go and buy it from the poweramp site or do we just re-install the trial version ?
post-12264145
Post #10,187 of 14,485
audioxxx
All you have to do is buy the Poweramp Unlocker app, and install, no need to reinstall the app.
https://play.google.com/store/apps/details?id=com.maxmpz.audioplayer.unlock
Reactions: proedros
post-12264256
Post #10,188 of 14,485
highfidelity69
And both need to be installed, I don't use poweramp with my ZX2 "tried it, did not sound right", but I do use it on my smartphone.
post-12264273
Post #10,189 of 14,485
audioxxx
I am referring to the Alpha version not the version at the play store.
Just incase you haven't tried the Alpha version. Its wortha listen, and if you don't have the app installed, how you going to open it? LoL:sunglasses:
post-12264322
Post #10,190 of 14,485
windstreak20
I'm sticking with the stock player (with disabled sound enhancements). For me, it sounds better, refined and natural than the jetaudio plus (with am3d), onkyo, gonemad and poweramp alpha version.
EDIT:
Included the "alpha version" from my original post
post-12264342
Post #10,191 of 14,485
Caruryn
Greece
Greece
Obviously none of the above apps are replacing stock player which i agree sounds the  most natural.The apps are to give different flavor,some have more engaging treble.other implement setting to widen perceived soundstage and for the money of 6-7 euro it's a good choice to have one more player on ZX2.Having too many will reduce battery even when not playing,as it is additional load on cpu.
post-12264345
Post #10,192 of 14,485
Whitigir
To clarify, Poweramp Alpha is different than Poweramp and is the version currently not available on App Store....only on the link I posted earlier by direct download and installation only
The "Poweramp" currently can be downloaded, and is on the Google store is the older version , which is "not good"
Reactions: cjpinner
post-12264594
Post #10,193 of 14,485
cjpinner
I agree, I tried the version from the google play store and didn't like it at all, the Alpha is another story, way better. For me it solved a lot of issues with clarity and soundstage. The stock player is good, don't get me wrong, I just like how the Alpha resolves the music, less "syrupy" than the stock player, tighter with a little more open soundstage.
There's also the added bonus of custom sorting options, the ability to download album art directly to your library and the ability to edit tags directly on your device. Way less hassle than tagging the files back and forth through the computer.
Last but not least I love the option to force the sound to Mono, I can't stand hard panning from the 60's when I'm wearing headphones. I have to say I'm loving this option.
Reactions: Cagin
post-12265849
Post #10,194 of 14,485
salavat
I tried both jetaudio and power amp apps. I found (and heard) distortions coming from jetaudio (plus  AM3D plugin), after a few listening sessions I could not find a reason to keep it.
Power amp (ALFA v3) is a different story. To me (with Angie) it sounds different than other apps I heard (gonemad, jetaudio). I did not see this mentioned in this thread (feel free to correct me if I am wrong), but this app PLAYS DSD FILES. Others (except Onkyo and Sony) do not.
post-12265890
Post #10,195 of 14,485
animalsrush
EDIT:
I agree .. The stock player sounds so good . I guess it all comes down to synergy .. With K10s especially stock player sounds more natural and airy.  I just turned on DSEE HX again and with K10 it is sounding real good. I had to turned it off for my ES5 as it sounded artificial. I have power amp paid version and did try the alpha as well .. It does increase the soundstage and adds width but personally it doesn't sound natural either with ES5 or K10.
Again my guess is stock player is doing something at HW level where most of these players are SW based.. But thanks to @Whitigir for his continued passion for finding the best tools for ZX2 it keeps us all on our toes.. Great job and i really appreciate that you try all of these before posting your opinions.. I know that is a lot of work
Thanks
PC
post-12266321
Post #10,196 of 14,485
AUDIOBREEDER
Stock app is serving me well. I'm not going to waste time and money for trying out other apps.
Moreover Sony did their best in integrating their software into android environment.
Also those who are experimenting with the apps and liking other apps is because they are using full sized headphones.
I am a heavy iem user and this Walkman pairs well with Sonys own iems like EX600 and above models.
Even with the MDR-1R is sounds good but not better than Fostex TH-X00. But that's another topic.
I hope my ZX2 lasts at least 3 years as I am going to hold off on all purchases as the new digital connections for headphones is worrying me and may make all my gear "worthless"
EDIT:
post-12266362
Post #10,197 of 14,485
cjpinner
I'm using Westone W60 IEM's with the poweramp Alpha and loving it. The westone' are known to be a little too smooth so that could be why I'm enjoying the added sharpness of the app. I'm sure the stock app pairs beautifully with other headphones though, it's still a great app, just a different "flavour"
post-12266368
Post #10,198 of 14,485
AUDIOBREEDER
How much volume do you need on the ZX2 for listening pleasure?
post-12266381
Post #10,199 of 14,485
cjpinner
Depending on mastering level I hover between 1/4 to 1/2 volume (Maximum 1/2 is usually too much) for most albums. I only use the option for leveling the sound between albums when I'm shuffling songs on playlists etc.
post-12266393
Post #10,200 of 14,485
Whitigir
Testing this
DP-x1 to solid silver TRRS 2.5 am style into th900
