JeremyLaurenson
- Jan 3, 2011
Anyone found a good TRRS-F-3.5mm to TRS-M-3.5mm adapter cable so my balanced headphones for the NW-ZX2 will work in a regular 3.5mm stereo device like an iPod/iPad/iPhone?
Will this work? I have K10U and new Moon Audio balanced cable to use with my ZX2 but sometimes want to use with my laptop's regular SE output.
http://www.amazon.com/gp/aw/d/B00L6C8PNU/ref=mp_s_a_1_1?qid=1452019093&sr=8-1&pi=SY200_QL40&keywords=trrs+trs+adapter&dpPl=1&dpID=31YxmGnb9TL&ref=plSrch&th=0
I think that above is for microphone + regular stereo TRS....not gonna work.
Speaking of trrs and wiring for jacks I'm thinking of getting a trrs cable made for my shure se425s. Before I do I've been trying to check how the jack should be wired up for the Sony. As far as I am aware it is -
the tip of the jack being L+ following the R+ then L- and then R- I
Is this correct?
Thanks
Cellphone is ok As it was designed to accept the TRRS, you will lose out the left Channel.....laptop is not ok as it was designed to accept TRS only and not TRRS, there is a slight different...enough to damage the socket if you would force TRRS into TRS
So, that Onkyo HF Player is a MUST for the ZX-2?
