SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
855 856 857 858 859 860 861 862 863 864
866 867 868 869 870 871 872 873 874 875
  1. Quadfather
    Both are fully burned in.
  2. HiFiGuy528
    that's too bad.... :frowning2:
  3. asquare3376
    Mike, when you find one, let me know. Been listening to Kimber 4.4 MUC-M12SB1 on XBA-Z5.WM1Z and it's the best sounding combo I have heard so far.
  4. robin1990
    Go to balanced out and never looked back. The difference between SE is getting obvious over time.
  5. Quadfather
    I matched up the volume better, and with Audio-Technica ATH-MSR7GMs, the QP1R and Sony NW-WM1A are so very close in sound quality. Both single ended. I am beginning to doubt last night's impressions. All things considered, battery life and the phenomenal user interface and album art is the clincher in favor of the Sony NW-WM1A. What a sweet piece of engineering!
  6. Whitigir
    Remember, Single ended, Sony has TRRS, which is 4nseparated polarity for Separated grounds and it has better sound quality. That would be a better matchup than just SE vs SE. There is no room to improve in QP1R, there is for wm1Z...then there is Balanced 4.4
    Quadfather likes this.
  7. Quadfather
    My Shure SE846s are drop dead gorgeous on Sony's balanced output. I have no balanced cables for headphones yet.
  8. Quadfather
    The 3.5mm is also balanced?
  9. nc8000 Contributor
    The 3.5 mm is seperate ground like on ZX2
  10. jamato8 Contributor
    I didn't know that! I have a TRRS just for the ZX2.
  11. Quadfather
    My Sony NW-WM1A needs more DSD. What is the best site to go to for DSD music downloads?
  12. kubig123
    I usually buy them from these 3 websites
    nativedsd.com
    Hdtracks.com
    store.acousticsounds.com
    I’ve also been able to convert some sacd to dsd files
  13. animalsrush
    My portable rig - sony wm1z + effect audio lionheart balanced cable + noble k10 CIEM
    Zero fatigue - 100% audio bliss
    audionewbi and tieuly1 like this.
  14. tieuly1
    How do you feel with Lionheart balanced out, I am in dilemma since I scare it will sacrifice Treble of Andromeda.
  15. blazinblazin
    I am using WM1A + Leonidas + Andromeda.
    For Leonidas you will have a more open sound. Treble extend higher for me.
    From what i read Lionheart is not a low focus cable but mid high.
    tieuly1 likes this.
