SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
833 834 835 836 837 838 839 840 841 842
844 845 846 847 848 849 850 851 852 853
  1. gerelmx1986
    formatted the microSD in the player? or the SD has exFat or Fat32 format? ALSO is your Music files in a folder called MUSIC?
  2. Lavakugel
    Didn't put music files in MUSIC folder, my mistake :)
  3. Whitigir
    Very common, may want to do a search function on the matter next time too :wink:
  4. nc8000 Contributor
    Just received the Nanuk Nano 310 and 320. The 310 is as close to a perfect fit for a naked 1Z as makes no difference without removing anything or having to do Dremel surgery. In the 320 the 1Z in the Sony leather case rattles around a bit. 310 and naked it is
  5. Whitigir
    Picture ? :D Gotta see something naked
  6. nc8000 Contributor
    Quadfather, Xamdou and Whitigir like this.
  7. buzzlulu
    So the 310 cannot fit the 1Z and it's Sony case?
    What about the Pelican 1020- 1Z with its Sony case?
  8. Quadfather
    The Lotoo Paw Gold Diana is so beautiful in person. It doesn't take good pictures. It is drop-dead gorgeous, and it sounds amazing, with boatloads of power.
    Jazzi likes this.
  9. animalsrush
    Traveling with wm1z internationally.. be prepared to get your bag tagged for extra screening., happened to me on my recent trip to India via London on work., my bag got pulled each time for extra check. I finally asked the TSA agent why.. he showed the pic and said it shows up hot on scanner due to it being gold.. so now I pull it out and put it along with my laptop for screening and all is well.. just avoids the hassle..
    Pc
  10. animalsrush
    I use pelican case 1020 with foam padding and it is perfect
  11. nc8000 Contributor
    No
  12. ledzep
    A 1060 with a 1062 foam insert works ok and leaves enough room at the bottom for a pair of iems.
  13. ledzep
    Tried a few different cases myself and settled for a CamKix Case for GoPro small with a customisable foam insert (medium)
    Piece of thin foam over to protect when closed, works for me.
  14. mikaelberg
    So I was stupid enough to buy the MUC-M12BL2 Balanced cable (http://www.sony-asia.com/electronics/headphone-extension-cables/muc-m12bl2) for my XBA-N3 for use with my new WM-1A that I ordered days ago...
    Ordered them at the same time from different places and just assumed the Walkman would have similar balanced output as the PHA-3... Needless to say, it didn't. Is there any plug I can buy to turn my two balanced 3.5 mm mini-jacks into one 4.5 mm balanced? Otherwise apparently what I should have bought for my XBA-N3AP is MUC-M12NB1 (http://www.sony-asia.com/electronics/headphone-extension-cables/muc-m12nb1).
  15. ledzep
    Yeah any 4.4mm will do, cut them two 3.5's off and solder it to the 5 pole 1499006858753959403301.jpg
