SONY NW-WM1Z / WM1A
post-13551586
Post #12,526 of 42,711
mw7485
Scotland, UK
Scotland, UK
Yeah I forgot to inform that I was on firmware 1.20 when I noticed that lag .... I don't think it's my film protector either since the rest of the touch screen functions is as fluid as I remember.
How about trying a reboot - wouldn't harm anything and it may work....
post-13551591
Post #12,527 of 42,711
audionewbi
My WM1A has really grown on me, so much that I am thinking of buying the WM1Z but I will try to resist the temptation and see what is next Sony magic is.
post-13551695
Post #12,528 of 42,711
blazinblazin
I have the same thought. Lol
post-13551735
Post #12,529 of 42,711
mw7485
Scotland, UK
Scotland, UK
...resistance is futile....
Reactions: pitch_black
post-13551773
Post #12,530 of 42,711
audionewbi
I've had a few long session with 1Z/1A. What makes 1Z attractive is having the same great sound using single ended out, the gap between balance out of the two wasn't large enough for me, present but for the duration I tend to listen to I wouldnt care. My loved Dita Truth single ended was wearing out and thanks for Dita audio I got a great deal on Dita Truth (awesome) and soon I will be enjoying the 4.4mm connection of my 1A.
post-13551837
Post #12,531 of 42,711
kubig123
NYC
NYC
Other than the play pause on screen lags a bit, other onscreen buttons was ok for me.
Personally don't think that the 1.20 add any delays, I found it smoother that the previous firmware versions.
post-13551889
Post #12,532 of 42,711
pietcux
Freiburg im Breisgau, Germany
The HD650s actually sound pretty good on most DAPs I've tried. I've paired them with a Jotunheim, NFB11 (super bright), and Aune X1S all for various periods so I'm familiar with how they sound when powered pretty well. For instance, the HD650s sound amazing to my ears paired with the Cayin N3 on high gain.
After testing the HD650 with the WM1A to proof your findings, I went back to my Z1r balanced out of the same DAP. Boy, what a difference regarding dynamics and speed. Not to mention the bass and everything else.... Sorry, but the HD650 needs and deserves more power than any DAP out there can offer. It really scales well with the rig you use.
post-13551906
Post #12,533 of 42,711
nanaholic
That was one of the things I thought of when deciding between the 1Z and the 1A in the beginning - the temptation of wanting the 1Z too after getting the 1A lol. Glad I went with the 1Z and I don't have to look back.
post-13551969
Post #12,534 of 42,711
gerelmx1986
Germany
Germany
me too my 1A has grown on me and often think on upgrading, but when i think of the future sony 40th walkman anniversary edition , I hold my breath
post-13554594
Post #12,535 of 42,711
JML
I was looking for a waterproof and super-protective case for airline travel or in-car Bluetooth use that would fit the WM1A player while it was inside the Dignis leather case (with or without the Sony wrist strap). I found one! The Nanuk Nano 310 fits perfectly, but you have to remove an inner rubber net and use a Dremel to cut down two internal screw posts for the net. The Nano is available from Amazon; it's polycarbonate and very much like a Pelican clamshell.
I just finished the surgery on a clear Nano and I'm very happy with the results. Pics of the post-surgery case to follow...
Reactions: kubig123
post-13554604
Post #12,536 of 42,711
kubig123
NYC
NYC
great idea.
thanks for sharing!!!
post-13554677
Post #12,537 of 42,711
Hydrored
post-13554681
Post #12,538 of 42,711
Xamdou
Wow thanks for sharing!
Any idea if the Nano 320 will fit the WM1A with leather case without the needs for any surgery?
post-13554695
Post #12,539 of 42,711
buzzlulu
What about fitting the WM1Z with its stock Sony case?
post-13554788
Post #12,540 of 42,711
JML
The leather-encased player will fit in the Nano without the rubber net in place, but the two screw-in net holders will dent the leather, which is why I took out the Dremel and went to work. I didn't try it without the leather case before I did the "surgery," because I had no intention of not using the Dignis case.
I have no idea about the stock Sony case, which doesn't come with the WM-1A.
I tried the larger Pelican 1040, and it held the player in the Dignis case, as well as the thick leather Dignis strap (far larger than the Sony nylon cord strap), but it was larger and too deep without added padding on top and around the sides from a fleece drawstring bag I had. The Nanuk cases come with a removable strap and have rubber protection on the outside; if you want a larger case for more stuff, they have a rubber net that separates items stored in top and bottom. Both makers offer different colors. The Nanuk latch is easier to open and close once you figure it out.
Interior sizes of four small cases from Pelican and Nano:
Nanuk Nano 310: 5.2″ x 3.0″ x 1.1″ (13.1 x 7.7 x 2.8 cm)
Nanuk Nano 320: 5.9″ x 3.3″ x 1.5″ (15.1 x 8.5 x 3.9 cm)
Pelican 1020: 5.31" x 3.56" x 1.68" (13.5 x 9 x 4.3 cm)
Pelican 1040: 6.50" x 3.87" x 1.75" (16.5 x 9.8 x 4.4 cm)
Reactions: echineko
Users Who Are Viewing This Thread (Users: 26, Guests: 56)
