SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
812 813 814 815 816 817 818 819 820 821
823 824 825 826 827 828 829 830 831 832
  1. Acemcl
    I have the dignis case as well and it's brilliant. Gives you access to all the functions and you don't need to take it off to charge or to load the SD card. I would also get a screen protector to go with the case tho....
  2. pitch_black
    I understand, why hide such a nice body..... but I want to sell it sometime in future better without scratches and dents.... and don't forget the dust
  3. pitch_black
    Thanks guys!
  4. Sleepow
    The Dignis is great, but as it does not cover the screen, it is not the answer to all case needs.
    If you put the player loosely in a bag with other hard edge devices, be mindful of the unprotected screen.
  5. nanaholic
    Definitely get a glass protector. I have a glass protector and the Dignis case, my Walkman is really well protected. Also worth mentioning is that the Dignis case comes with clear stickers which is designed for you to apply on the remaining exposed areas that is not protected by the case - which is the top area and the SD card flap. Once you put all of those on the player with a glass protector the Walkman probably cannot be more well protected (the only remaining protection is to add some dust covers to the ports). The attention to detail is what makes the Dignis case worth getting.
  6. daniel_hokkaido
    Hey thanks for the info.
    I will be using the Z5 iems and find them dark enough as it is ... so the KANN may be a good option
  7. gerelmx1986
    a bit off-topic cut do you know someone who has removed the gray filter sponges out of the xba-z5 nozzles? Any benefits or cons?
  8. mw7485
    I'm using Z5's with the 1Z - and I find the base absolutely fine - and I'm used to ER4's! The base is very present, but never overpowering. I find the synergy between the 1Z and the Z5's to be absolutely sublime in balanced mode. Given the cost of the players involved, an audition would be a sensible idea - perhaps @ CanJam London?
  9. ledzep
  10. ledzep
    Official Sony ok not the best
    Dignis top quality, but expensive and can mark easy ( depending on how you use it )
    I've had both and now settled on a Benks clear thin tpu case , perfect fit plenty of grip and nicely shows off the player not to mention cheap.
  11. animalsrush
    I absolutely love the Sony case.. it makes player look classy and shows off the right bits :wink:. When i travel I use pelican 1020 case with custom foam inserts that protects the device with case on..
    Pc
  12. blazinblazin
    I think Dignis case still having the best fit out of the leather cases.
  13. gerelmx1986
    I love the beauty Naked showings it's glory :D
  14. daniel_hokkaido
    Hey ... no and I wouldn't think it a good idea. There's no cross overs in the Z5 so that sponge is likely important
  15. gerelmx1986
    thanks for the info, and yes I remembered when I removed the sponge front the H3 the had piercing highs. Better leave the sponge as is
    rhull1973 likes this.
