SONY NW-WM1Z / WM1A
post-15421548
Post #31,231 of 32,511
Redcarmoose
1A/1Z has no video capability.
He’s talking about using the DAPs with a laptop for movies, as there is a slight delay which causes speech to not sync. So instead of using a direct DAC mode, which is obviously best SQ, you switch to Bluetooth and the delay is no longer an issue.
post-15421581
Post #31,232 of 32,511
Ameerzs
Malaysia
Malaysia
There are two work-arounds. One is movie playback software that lets you move the audio sync-point forward or backwards. I just go Bluetooth and it’s fine.
for movie its not really important since can just use the LDAC, but when watching Music Video, the difference is too much to ignore, DAC mode give alot of details and resolution, much lower floor noise.
post-15421763
Post #31,233 of 32,511
proedros
Athens , Greece
Athens , Greece
anyone here with a link on where to buy new/spare WM1A/WM1Z batteries ?
thanx in advance
post-15421817
Post #31,235 of 32,511
captblaze
Blazin it up in the land of Lincoln
post-15421829
Post #31,237 of 32,511
Whitigir
post-15421835
Post #31,238 of 32,511
proedros
Athens , Greece
Athens , Greece
post-15421837
Post #31,239 of 32,511
meomap
California
California
post-15421942
Post #31,241 of 32,511
mw7485
Scotland, UK
Scotland, UK
thanx in advance
Post #26383. The battery in the 1Z and !a are common parts. Mine came labelled as a 1A battery - but they are same part no.
Reactions: proedros
post-15421944
Post #31,242 of 32,511
Whitigir
I bought a spare battery before, and yes, they are the same.
The hardest part is to remove the battery and solder in the new one....you do not want to short the “terminals” out at all. It can blow in your face!!!
that is totally serious and no joke
post-15422008
Post #31,243 of 32,511
mw7485
Scotland, UK
Scotland, UK
Totally agree, although the wires do come pre-tinned and the live terminal has a protective plastic sleeve over it which should only be removed immediately prior to soldering. The other danger is shorting the live terminal against the chassis via the soldering iron - definitely a job for a steady hand!
Reactions: Whitigir
post-15422099
Post #31,244 of 32,511
proedros
Athens , Greece
Athens , Greece
Reactions: nc8000
post-15422108
Post #31,245 of 32,511
mw7485
Scotland, UK
Scotland, UK
...and I think they can order pretty much any parts you require. Shipping was about two weeks for me.
If you are going to do this yourself (or get a non Sony engineer to do it), I strongly suggest that they review the maintenance manual. There are a few double sided adhesive strips that you'll likely need to replace. They are all indicated in the manual though. Good luck!!!!
Users Who Are Viewing This Thread (Users: 29, Guests: 60)
