SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
  1. LinstantX
    No one knows what output impedance has NW-WM1Z?
  2. LinstantX
    But on the balanced connector.
  3. nc8000 Contributor
    Sony don’t give that info, the designers said during an interview that they consider that information unimportant
  4. RollsRoys
    less than 1 Ohm. Source
    Sony's dap balanced output is one of the least hissing on the market
    Sp12er3 likes this.
  5. LinstantX
    Thanks for the clarification.
  6. silvahr
    Thank you for the info.
    Right now I'm using SE-->RCA to my Violectric V100 and it's really good. The volume on WM1A is set to max and then use amp to control the output volume. Seems to work well without degradation of sound. It's really a great piece of gear.
    MrLocoLuciano likes this.
  7. Vitaly2017
    This song is so cool can someone try and share how you liked it )
  8. aceedburn
    Yes, i love the WM1A as it does what it supposed to and works beautifully. I put the volume on the WM1A at 100 when i connect it to my magni 3.
  9. buzzlulu
    Which brand SE->RCA cable are you guys using?
  10. aceedburn
    I use QED. Good build and fantastic reproduction.
  11. meomap
    I use AudioQuest, mid price.
  12. buzzlulu
    Thanks to both of you
  13. silvahr
    I’m using a cheaper one and the results are great. Probably I will get an Audioquest Golden Gate.
  14. Vitaly2017
    May I ask why you use se and not balanced from dap?
  15. nc8000 Contributor
    he might not have any balanced equipment to connect to
