nc8000
I can only think that these new walkmans may have the poorest battery life among all sony daps and even compared to their very old mp3 players.
That would be my guess as well
Like ali android daps. Android drein battery very fast.I can only think that these new walkmans may have the poorest battery life among all sony daps and even compared to their very old mp3 players.
It actually looks pretty good, according to the specs. It looks like the DAC/AMP accounts for much of the battery usage, and not the Android OS. The S-Master is the difference between the ZX500 and other Android DAPsI can only think that these new walkmans may have the poorest battery life among all sony daps and even compared to their very old mp3 players.
Its just weird because bluetooth dac and usb dac where added via software update to 1a and 1z.
So what was the big deal with zx500 not having this option. What if I need these features hmmm? Even if it drains battery duh!
On other hand I am very happy to see sony going to android cause lot of people use streaming services and I do it 99% of the time. So this zx500 is exactly what I always wanted to have.
Big question any one knows if spotify/tidal can work with offline diwnloaded content?
Assuming you always have your phone with you, BT receive mode on current Sony DAPs give you full streaming capability, especially if you have LDAC. In my case I subscribe to Apple Music so the AAC receive mode gives me full resolution streaming from my iPhone since AAC is native to Apple Music. Personally, I don't see a scenario where I only have my DAP with me but no phone.
I dont know if src affects Bluetooth dac feature. Or if it is really full res without any up or down sample.
But my 1z sounds 5% better in usb dac mode and it shows 48khz rate no matter what
Speaking of processing that drains battery...
How do you find the DSEE-HX to be? Does it seem to improve sounds? In what instance (it says it is intended to improve for lower-bit-rate songs, e.g., below CD rates).
Actually no. The Apple Music files are decoded, then mixed with other sounds from your phone and then again encoded to aac before being send over BT so you get a double encoding of the original music
That's interesting. Where did you get that info? My understanding is an AAC encoded file/stream should transmit via Bluetooth AAC codec unaltered.
It has to work that way in order to mix in other sounds from your phone like in game sounds if you play a game at the same time as music, notifications and so on. There is nothing like Windows kernel mode where one proccocess can gain exclusive control over the sound path. Now whether this is actually audible/noticable is another matter
I have never heard more than one sound source on my iPhone. When I get a ring, playback is temporarily suspended. When I open an app, the music stream stops immediately unless I disable sound in the app. Lastly, even if I could play sound from multiple sources that can easily be done via hardware MUX. Since sound frequency is only 20 kHz, a MUX can play multiple separate streams, but make it appear as one blended sound. Same concept as network switch. Absolutely no need to convert AAC to PCM, then remix everything to PCM, then recode to AAC. If this is how Apple implemented their digital audio, I would be shocked because it would be unnecessary CPU cycles. I am purely speculating here since I don't know how Apple implemented their hardware.
