siruspan
- Sep 11, 2010
There wont be any higher end than DMP Z1
What about the DMP Z2 not to mention DMP Z3
DMP Z2 wont be even close for another 5 or 8 years....judging from how long wm1z isnt even being replaced yetWhat about the DMP Z2 not to mention DMP Z3
A Z500 to replace/superceed ZX300 is coming
I’ve not compared it to the 1Z or the Calyx, but I’ve connected the Monoprice AAA THX to the 1A with great results and the Little Bear B4 Tube amp with good results.
I heard zx300 and quiet liked it very close to 1z
1A is not far away from 1Z. Different sound signature is real between different choices of components. Both should be on similar level as they are from the same engineered architecturali heard that 1a is somehow better than zx300 , so that means that 1a must be closer to 1z than what i think....
Even the 1A itself is built with quality components that you don’t see on SP1000, and I am sure of that. MELF resistors are high quality resistors dedicated toward audio performances. PML caps and Electrolytic caps are high quality for that. Except the caps and being used on 1A is from Phillips itself, while the 1Z caps and resistors are customized under Sony specs. I am not sure from which manufacturers, but there are a little differences
So I`m going to buy the 1A in a couple of days.
Here is the thing.. I DEFINITELY want the Japanese version and I`ll be getting it from Ebay from Japanese sellers like all my other Sony gear. BUT everyone is writing big warnings about the display being Japanese only.
Has anyone any experience with this or know if there is any way around it?
I have the Japanese version of the ZX2 and with that I just chose English display language the first time I switched it on and I`ve been good ever since..
I've been finding it weird that people desperately want the non EU version of the Sony players. It's very easy to remove that capWhat's the reason for the Japanese version?
If it's because of the EU volume cap then that's simple to remove.
I may be wrong but I think there is/was a Japanese only domestic version and a Japanese Tourist version with English.
You could also buy a US, Australian version etc
Yes it`s mainly because of the volume cap! I use the EU version ZX1 for work and every so often it turns the volume all the way down telling me to "check the volume level". It infuriates me beyond belief
Also there is something mentally for me knowing that it`s a Japanese version. ALL my other Sony gear is Japanese versions so I`d like to continue down that path^^
On the ZX1 and 2 you could not remove the volume cap but on all the players based on the Sony OS you can just use the RockBox tool to change region and thereby remove the cap, enable features and change gui language
I mean, all WM1* are Malaysian, technically, but whatever works for you, eh?Yes it`s mainly because of the volume cap! I use the EU version ZX1 for work and every so often it turns the volume all the way down telling me to "check the volume level". It infuriates me beyond belief
