Kitechaser
Thank you for this. I agree with everything you said. 2.0 outside of 3.01 is the best sounding to my ears, minus the smaller stage, it is lower on details than all the DSP options turned off including direct sound on the 3.01.I assume your using the 1A?
The player type should also be noted as the firmware is different sounding on each.
2.0 was fine with 1A, but was missing Bluetooth receiver option and DAC option. Also 3.0 introduced vinyl sound filter but 3.0 was unstable, also it took forever for the database to build.
3.01 was a huge jump in sound quality for the 1A over 3.0. Though it also changed the 1Z a little. Still many users use every firmware as it’s subjective which is best. Also remember people are using different IEMs which have different sounds.
But depending on your sound preference, nothing wrong with 2.0 as long as you don’t want the extras.
The only firmware you can’t go back to is 1.0 which came with the very first Walkman introductions. No one I think liked it anyway. But you even now have people liking the very first firmware revision over anything new.
But it’s strange that 1.0 is not around as you would think people may have needed it? Though the next update will as fairly fast if I understand things.
As Walkman builds moved along newer ones actually came with newer firmware. I purchased mine in November 2017 just as 2.0 was about to be released. But now I run both the 1A and 1Z with 3.01 as I use the Bluetooth receiver function as like the sound otherwise.
I found one of your earlier posts with a link to all the firmware updates, and the quick A/B test was pretty conclusive.
Crazy how much the sound on this DAP changes with firmware updates.
