SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
  1. Whitigir
    Now imagine DSD512 kakakaka...still cheaper than 100 vinyl though...isn’t it ?
  2. ccschua
    is there anyway I can stream spotify to wm1a ?
  3. noverbeck
    You could use it as a bluetooth DAC, send Spotify from your phone/pc to the WM1A.
  4. nc8000 Contributor
    Yes you can use the WM as dac either over BT or USB
  5. Kitechaser
    End game combo.
    DKNTy, Aslshark and kubig123 like this.
  6. endlesswaves
    Wait till you have tried the 1960s 4 Wires :ksc75smile:
    Kitechaser likes this.
  7. Kitechaser
    Don't even get me started hahaha. I'll have to sell a kidney to get that one :)
    I can't wait to try out the 1960 2 wire with the DMP-Z1, that is going to be epic.
    As far as this combo, man you were not kidding, this cable is incredible, worth every penny. Now I can see why people happily drop 2 grand on iem cables, no graph will catch what I am hearing, but it's like taking a scalpel to the music and chiseling out every minute detail possible :ksc75smile:
    I have the cable bug, I can't unhear what I am hearing, only way to go is up.
    endlesswaves likes this.
  8. gerelmx1986
    With the 400GB micro sd card, all flac 16/44.1 , there are like 26000 tracks, now with wm1A and the 1TB it would be roughly 51000 if we theorize only 16/44.1
  9. auronthas
    I am able to play WM1A songs in Hiby R6 via USB DAC but not the other way round (USB method).
    I have set WM1A to USB DAC mode, but it stated no digital signal ...
    What should I do?
  10. nc8000 Contributor
    You need to be on fw 3.0 or 3.01. On the front screen select usb dac and then plug a cable from your source into the WM and it should just work. Maybe you have to go into usb settings and tell the WM to not try to charge over the usb connection, your source might not be able to supply enough juice for that
    auronthas likes this.
  11. nc8000 Contributor
    Yeah I have about 38.000 flac files on my 1Z with a 512GB card
  12. auronthas
    Yes, my firmware is 3.0.1. I did the same as you described, USB charging is unchecked at setting. Hmm, what went wrong?
  13. nc8000 Contributor
    No idea, I’ve just briefly tried it from my pc to see it worked, nomally use my 1Z as a stand alone player
  14. mwhals
    My almost 10,000 16/44.1 Flac files occupy 256 GB. You must be using more compression than me.
  15. nc8000 Contributor
    Level 5, but I probably should write 512GB card plus the internal 256GB totally filled up
