- Oct 14, 2013
Isn’t A standing for Apple ? Any Apple devices and not limited to IPhones ?
I didn’t do anything. Rebooting both devices solved it.No problems with Mojave on any of my systems.
What does Disk Utility day the internal drive format is and did you run Repair against it?
Just picked up the 1A from Best Buy on Thursday to replace my ZX2, also upgraded from the Z5’s to the ier-m9’s. I’m very impressed with this combo. Hard to believe the sound will still improve as I reach the 200 plus hour mark. Two questions though, what are people’s opinions, who may have upgraded, about the Sony Kimber balanced cable, as opposed to the one provided with the M9’s? Just wondering if it’s worth spending the extra cash on. Also, I purchased a Samsung 512gb sd card. Unfortunately, I can’t get album artwork to transfer to the sd card, but have no problem when transferring music files to the internal storage. I’m currently using a Mac. Any suggestions?
Thanks for the effort in explaining the process. Unfortunately, I don’t quit understand though.Album art must be baseline jpg not progressive and can either be embedded in the music files or a seperate jog in the same directory as the music files. Also all your music must be in a Music directory on the card, not in the root
You need a specific codec for the pictures, which is baseline. You can either embed it in the metadata or put it in the same directory as the music with the file name being the same as the directory but still baseline format . Example. If your folder is named dj_taq_ongaq, your picture must be dj_taq_ongaq.jpg and also baseline formatThanks for the effort in explaining the process. Unfortunately, I don’t quit understand though.
Ok, thank you, I’ll try it tomorrow. I appreciate itYou need a specific codec for the pictures, which is baseline. You can either embed it in the metadata or put it in the same directory as the music with the file name being the same as the directory but still baseline format . Example. If your folder is named dj_taq_ongaq, your picture must be dj_taq_ongaq.jpg and also baseline format
Yes I have it uses more battery powerAnyone else noticed a drop in batery life in 3.01 all effects on?
