SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
  1. Quadfather
    I always make sure to pull album art off Amazon and it works because it's Baseline
  2. ryaneagon
    Thanks.
    I'm going to give XnViewMP a shot and try and batch process, if that doesn't work I'll pull from Amazon, being I'm having an issue with only a few albums.
    Thank you sir!
    Quadfather likes this.
  3. Quadfather
    I have several terabytes of music and I am now through the letter q for having it all Baseline and workable on the Sony. I am making real progress LOL in a few more weeks, I will be done and then I'll back it up on five different hard drives. Does anybody know of a good program to scan for any audio file corruption?
  4. NaiveSound
    How is this done? Because music is bought on Amazon ?Or how else?
  5. Quadfather
    In Google image search you put the artist, album name, and Amazon and make sure the image you choose is hosted on Amazon. Michael Jackson Thriller Amazon. I usually choose one of their large or one of their medium sized images.
  6. ryaneagon
    Sounds like a party! Well, I'm going to just stick with the few that have issues displaying on the Sony. Downloading from Amazon did work.
  7. Quadfather
    I am glad it worked.
  8. ryaneagon
    What an inconvenience, too bad Sony can't design the software to accommodate progressive images, sucks that all my other devices work without issue...Oh, well, can't have everything. :wink:
  9. NoMythsAudio
    Download and install Tag Scanner (Windows only). Connect your 1z via usb to the computer. Open Tag Scanner. Locate the MUSIC folder from 1z, drag it into Tag scanner, select all (ctrl+A), click save; Tag scanner will re-encode all the images in baseline jpg. And you’re done. Saves you a lot of manual work and time.
    **pay attention to the image size in the preferences section of the program as you can use this to also resize to smaller images. I can’t remember the default size of cover in the program as I changed mine long ago.
    Cagin and rcoleman1 like this.
  10. ryaneagon
    Perfect! Thanks for the info.
  11. ryaneagon
    Well not much luck with tag scanner. I didn't have a problem importing via walkman music folder, set the embedded covers to 800x800, ctrl-a, and save...took a bit save, but that didn't solve the problem with the albums with missing art. Any idea?
  12. Dtuck90
    My WM1A has crashed 4 times in the past 24 hours since I used USB DAC with my MacBook Air. This is the first time it’s crashed since upgrading to 3.0 the day it was released and was only the second time I’ve used USB DAC. Can’t be a coincidence.
  13. Stephen George
    it doesn't have to be..i use a product on the PC called "Tag & Rename"
    you select the files, press the globe and it'll do the google search for you
    you can then just drag the cover you want and it does the rest
    i found the smaller the cover the better...T&R will set everything to 200X200
    higher res pics do nothing for you
    roses77 likes this.
  14. Stephen George
    smaller the better....the sw i use sets it to 200X200 and haven't had any issues
    supposedly with 3.0 you can do away with embedding them and just use folder.jpg
  15. NaiveSound
