Anyone using Mr. Speakers AFC on balanced with the WM1A/Z?
If so, how is the sound? I have been using the Lime Ears Aether CIEM for the last 16 months on balanced with my WM1A and i love the synergy between both, but i´m considering on getting the AFC to use while at home.
Here is a DAC mode tip. I think the Sony Docks are too tall and causes unnecessary strain on headphone cables. I initially just tried to lay down flat but found the volume controls a little hard to use. I then found a gadget I use for my phone and really like the usability with the WM1z positioned right next to my MacBook.
Just get the cradle, less hassle and it charges, and you get a SQ improvement. The side Mini-USB is the weakest link; the way it’s shown in the picture. I’m pretty sure the picture predates the cradle.
My 1z reboot three times since upgrade to FW3.0 in a week. Every time has similar pattern, it reboot on the first track of hires FLAC
on internal memory after listened to DSD on external SD card.
I may re-install FW 3.0 next week but not want to do a factory reset as it also reset the counter.
I can make such support machined from solid stainless steel 316N, the most non magnetic to not affect the sound signature: the body from metal to assure stability and the cradle from Ertalyte ( thermoplastic polyester) to not scratch the DAP.
