Aren't those version 1.02? Or am I reading them incorrectly?Yes! THX!
SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
Redcarmoose
Nice. Thanks! Are those Windows version firmware installers?
Edit: Sorry, you already said they were!
Just so you know, I used his Dropbox to go back to 2.0 with the 1A. They worked perfect. He has all the FW listed so you just look for the one you want to roll back to.
Redcarmoose
Yes, they are my mistake and his! Funny too as I rolled back with those till I found out they were 1.02!
Piotr Michalak
question for iPhone users:
1) For bluetooth, when i pair my output says "AAC" which i believe is lossy even though i'm streaming music from Qobuz or Deezer in HD quality -- is a limitation of iPhone or do i have some setting incorrect?
2) for actual USB DAC i use the apple camera dongle and even with unchecking the "charge when using" option on the Sony i still do not get any sound coming out from iPhone stream.
do i have some settings incorrect for both BT quality somewhere?
thanks
Yes, unfortunately iPhone doesn't have a quality bluetooth option ;-( no APTX or anything like that. It sucks, yes. For example, with Hugo2, my iPhone as a source was generating some unaudible hissing.
As far as I know, yes that's an iOS limitation, no LDAC support.question for iPhone users:
thanks
Yeah, I'm a day late and a dollar short on my posts today. Just noticed you had already discovered this! So, what version are you going to use with the 1Z? I haven't yet listened enough with 3.0 to make a judgement.Yes, they are my mistake and his! Funny too as I rolled back with those till I found out they were 1.02!
Redcarmoose
After today I’m running 3.0 with the 1Z but found FW 2.0 to be better sounding with the 1A. Oh.... and that early 1.02FW was causing issues with the 1A for some reason? Scary.
Disclaimer:
Everyone has different IEMs and different likes in sound signature; your results may vary from mine. Cheers!
To get slightly wordy.......3.0 with the 1Z is like Christmas. I had this feeling that I rarely get after I started to get used to what I was hearing. To me 3.0 with the 1Z is an experience. It’s like the old Sony sound but updated into the future? I love it. Makes the 1Z a whole new player.
Disclaimer:
auronthas
- May 19, 2017
Don’t use these unless you want to go back to FW 1.02.
Here the links of the most recent FW
V.1.20 - Mar. 22,2017
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V1_20.exe
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V1_20.dmg
V. 2.00 - Nov. 09,2017
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V2_00.exe
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V2_00.dmg
V. 3.00 Oct. 04,2018
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V3_00.exe
http://walkman.update.sony.net/fw/pc/WM1/NW-WM1_V3_00.dmg
normie610
Contrary to many, I find the 3.0 on 1Z to be warmer by quite a margin. Soundstage goes wider but not too much. Notes are more solid and controlled with less reverb. I really like the vinyl option surface noise, as vocals become even more lush, truly analog-like. All in all, a really nice update, great job Sony!
bflat
What's your iPhone? I tried on my 4s (yeah, no new iPhone yet), it needed the camera kit and yes, charge this device from the source to work. but it did output audio.
iPhone Xs Max with CCK 2.0. I only plan to steam Apple Music and Netflix so don't see the need for wired mode. AAC BT is exactly what I was looking for.
I can’t believe you think it sounds the same as 2.0?
I just got my 4.4mm cable and relatively new WM1z owner so certainly not an authority. Either way, I am very pleased with how my Laylas sound.
Redcarmoose
Started with the 1Z in November right as FW 2.0 came out. It was confusing learning how the sound changed with burn in and the change to 2.0. But I was able to get a better understanding with the player at 200 hours of burn in with 2.0.
But it really is a personal thing and everyone perceives things different. Plus we all have different IEMs. There is also the new toy phenomenon. At times anything new sounds better, when in reality it’s just new.
But my understanding is we tend to notice things right off then other things start to emerge days and days later.
We will read how everyone reacts to this update. I can kinda tell already that there will be both DAC implementing issues with folk’s computers as well different perceptions of the sound of the update on the three players Sony made.
Stephen George
- Jan 11, 2017
you can remove the embedded cover files form files using mp3tag and export a single picture
very curious to see how much i would save, but stuck on the export step
so i just selected 1 album to test it and when i highlight, go to quick tools, export cover to file, add %_directory% and then ok...it processes files, but comes up with zeros and nothing is in the directory..i then tried click front cover only and same results
is the filename generated cover.jpg or folder.jpg?
TIA
Redcarmoose
Are you trying to listen to older recordings which are thin sounding and listening if the player is adding warmth, or listening to modern recordings?
I say this because 3.0 will sound almost warmer if you listening to a modern HD track with a bunch of low end. It’s strange because more detail on a bass heavy track CAN make 3.0 sound super warm?
3.0 sounds warmer with this track in 192/24?
I think it’s the capacity now which we have?
But who knows? We have only had this for a day. Anything could happen as far as folks perception!
NaiveSound
- Nov 8, 2015
Yeah the more I listen the more I like 2.0 over 3.0. 2.0 to me is warmer...3.0 being a little brighter but I don't know if there are any more details really . It's just brighter. I wish I could have 2.0 sound with 3.0 software
My friends fourte is too sharp with 3.0 for example. Unpleasantly so. And I'm not sensitive to sibilance
Well.
Another thing. All dap manufacturers don't recognize or admit that software does alter sound... I find that a little *elementary school temperament *...
I guess I'll keep 3. 0 because of the awesome Bluetooth/usb dac features that should of been available from day one of this player.
Well.
- Status
Total: 9 (members: 0, guests: 9)
