SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
  1. fiascogarcia
    Don't know if you've seen this, but it might interest you!
    https://www.headfonia.com/aultima-sp1000-ss-and-ak380cu-vs-sony-wm1z/
    proedros likes this.
  2. Redcarmoose
    Interesting to read 80% of this thread and still we only have ideas on how to approximate the tone the of 1Z prior to the last 2.0 firmware update.
    I’m now using slight EQ changes taking three notches off the mid-band dial and one single notch back off the treble dial in the dial EQ settings. I did try to use the other setting changes which were first suggested by members here after the update to 2.0 occurred, but feel the suggestive settings did not replicate the warmth of the prior sound signature.
    Am I missing something here, or would it not simply be standard for Sony themselves to suggest a way to get the old sound signature? I like the changes in volume power and extended sound-stage with 2.0 but would like to detour Direct Source (Direct) and get a slightly warmer tone without going back to the older FW?
    I know this may have something to do with Sony basically saying “OK” it’s better now? Still it seems beyond my ability to test the frequency response and obtain a quality profile frequency graph to try and replicate the old warmer FW prior to the update. It seems as it would be simple EQ science or maybe beyond such stuff?
  3. bana
    Thanks, but they are sold out on almost everything.
  4. fiascogarcia
    On page 1136 Kubig123 had a post that has a link to re-install 1.02.
  5. dougi555
    Ermmm..... How?
  6. kubig123
    With the latest firmware you can play mqa and ape file on your wm1a/z.
  7. Fr_eak
    And the result is fabulous!
    NickL33 likes this.
  8. gerelmx1986
    But as i have read the MQA is a kind of a lossy compression.. i'd stick with 24-bit FLAC and DSD
  9. Fr_eak
    No definitely not... I know MQA is a bit controversial in many discussion forums but from my own experience comparing the Buena Vista Social Club album between 24/96 flac and MQA the difference is apparent that the MQA is better. The soundstage, the precise positioning of equipment and timing is superior.
  10. gerelmx1986
    Sounds kinda like i hear with DSD files (2.8224MHz). On the other hand good sony is opening their minds up and accepting Ape files, personally i don't use ape files but for those folks who have ape libraries good to have an alternative
    kms108 likes this.
  11. kubig123
    I read that too.
    The album could be also a new remastered version, the one I bought (the doors) was remaster but not I a good way.
    But if you like it enjoy it, this is what matter!
  12. gerelmx1986
    APE playback test and evidencee ibused high compression, plays fine
    kms108 likes this.
  13. mw7485
    All MQA stuff is re-mastered as part of the MQA process - at least, stuff that wasn't mastered with MQA as part of the original mastering process (if that makes sense!).
    I like MQA and to date, the few (classical) albums I have bought in MQA have all sound very good indeed. Not a duff entry in the list. The one thing I would like to know is to what extent the Walkman can unfold an MQA file? Sony has been curiously quiet on this front, and I think they should come clean so that people understand better exactly what the unit is capable of.
    dougi555 and kms108 like this.
  14. Redcarmoose
    Yes, like I said, I’ve read almost this whole thread. Perfectly aware of how to go back to FW 1.02.
    Just asking if anyone else has been able to approximate the warmth of FW 1.02 other than the EQ. I know there has already been other posts on the subject. My question came as wondering why Sony has not released something like an EQ setting to get to the sound of 1.02?
    I’m perfectly happy using EQ and think I’m getting both the warmth of 1.02 as well as the soundstage and power increase of 2.0 FW update.
    It just seems something like this would be more documented and scientific, like a graph which shows frequency responses equally measured with 1.02 flat............and FW 2.0 with EQ.
    I’m happy doing a simple EQ for one set of IEMs and maybe would not be one of the 1.02 Luddites.
    flyer1 likes this.
  15. equalspeace
    The stage on this 1A man... so damn good.
    NickL33, kubig123 and productred like this.
