SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Oct 6, 2017 at 11:15 AM Post #15,031 of 45,723
I'm still trying to work out why on my 15 Inch hp 360spectre laptop all the font is way too small, really scrunched up and there is nothing in the settings to change size of font yet my screen resolution on windows is at the recommended setting and if I change it upsets all other programs correct ratio and although the music centre font is a tad bigger it is still not standard size. Sub menu font size is acceptable however which is strange and also downloaded this on my dad's 17 inch hp envy laptop and has perfectly fine just like media go size font yet on mine is for some reason very very small to point cannot even make out the text with my glasses on!.
Was wandering if it is too do with my screen been a 4k one something going on with the program and screen resolution there? Cannot fathom it out so have to use media to still for now.
See on my dad's copy any dac can be used through this program so guessing another reason why they done this music centre as media go has never worked with third party dacs.
Oct 6, 2017 at 3:49 PM Post #15,032 of 45,723
Dvdlucena
Andaluzia, Spain
DID someone tried Sony nw1z and chord hugo 2?
i'm looking for some comparisons but didn't find any
thanks
Oct 6, 2017 at 5:26 PM Post #15,033 of 45,723
mw7485
Scotland, UK
thanks
I take it you mean a comparison between the two rather than using the 1Z as a source? Have you had a look in the Hugo threads?
Oct 7, 2017 at 2:19 AM Post #15,035 of 45,723
nanaholic
I have both, but I use them completely differently. Not sure what sort of comparison can be made.
Oct 7, 2017 at 2:20 AM Post #15,036 of 45,723
hamhamhamsta
California
Nvmd..
Oct 7, 2017 at 6:00 AM Post #15,037 of 45,723
Kira69
I'm going to buy finally a WM1A.
Who has tried WM1A with iBasso IT03? It's a good synergy?
Any comparison or personal views between WM1A and Mojo?
I really appreciate evety answer. Thanks folks.
Oct 7, 2017 at 6:46 AM Post #15,038 of 45,723
jb001e9634
I've bought a used 1A (400 ish hours on it) and I've had Mojo previously.
I sold the Mojo to go back to an all in 1 solutuion and knew/assumed for the money I'd be spending the SQ wouldn't quite be as good.
Used a Pioneer 100 first, sounded Ok, defo not Mojo, ordered a DX200 next, very good device, punchy, clear sound, lots of detail, wide soundstage, returned that because it got VERY hot and FW issues - shame really.
Bought the 1A, sound is different, still detailed, great bottom end, not as fast as the DX200, I've seen people describe the sound analogue and I would agree, reminds me of full size Rotel pre and power setups I've had previously.
I'm using IE800 with the 1A and it seems a good match. Looking at options to try the balanced output next, but will Need new IEMS.
Oct 7, 2017 at 9:18 AM Post #15,039 of 45,723
aisalen
Yes, it is. I am using IT03 with my 1A in balance. I am using spiral dot ear tip, nothing more to ask in terms of sq.
Oct 7, 2017 at 10:34 AM Post #15,040 of 45,723
pietcux
Freiburg im Breisgau, Germany
Besides ging balanced I find the Sony EX1000 to pair much better with the WM1A.
Oct 7, 2017 at 11:33 AM Post #15,044 of 45,723
eddie0817
Damn, You have all those fancy cables ....combined to be even more pricy than 1z itself
Yes, bro.
Previously I am use LOTOO PAW GOLD, just upgrade to 1z yesterday.
List down the cables I have for now
Toxic SW22 v2, GSP 8 wire, piccolino 4 wire
Effect audio Thor ll, +
PWaudio 1960s 4 wire
Han Sound audio Aurora, Agni, Zen 8 wire
Quite troublesome for me to change their jack to 4.4 mm. :)
Oct 7, 2017 at 11:39 AM Post #15,045 of 45,723
pietcux
Do you use Source DIRECT or you have it disabled?
with my XBA-Z5 i have DIRECT ON, but with these sennheiser HD201 had to disable it to turn more bass
I only use Source Direct. I don't mind that all headphones sound a little different. And it saves battery.
Status
