Should I convert all my flacs to mqa? They are all 16bit 96khz.Amazing quality with small size. Thumb up for MQA files
Sony NW-A50 Series
I don't think we can convert itShould I convert all my flacs to mqa? They are all 16bit 96khz.
Aevum
- May 15, 2007
Keep them in Flac, MQA is snake oil,
Its basically AAC with software enhancements and heavy licensing fees.
fish1050
MQA processing is done during the recording and mastering process and isn't something end users can convert to. Mostly a benefit for streaming HiRes audio but you can purchase MQA tracks online. Whether they are worth it or not is questionable especially since you could only play them on devices that support MQA and there aren't many.
Blazer39
- Apr 30, 2015
Hey here is the thread where I learnt about the 'problems' with Sony line-out. It appears I didn't continue reading the thread when I initially did the research because it goes onto indicate it is still a valid possibility even though it may not be true line out.
https://www.head-fi.org/threads/sony-nw-a40-series-nw-a45-a46-a47.854779/page-46
Cliffs:
-3rd party walkman to lineout cable works on sony nw-a45, and when in operation the volume level level is unimpeded by the volume rocker indicating the device is at least attempting to maximise its signal in at attempt to create a LO signal
-The 3rd party cables are cheap (9 dollars) therefore very unlikely they have an inbuilt DAC indicating you are getting the internal processing from the device and not some junk
-Head-fi regular user vouches for using a regular HO on Sony devices . They did not own the a45 but had the a17 for years and relayed his experience with Sony products in that the quality of their HO is in effect as good as any official LO he has tried. He deemed the need for the 3rd party cable unnecessary given the superb quality and compatibility he was able to achieve with varied portable AMPS using the HO from his a17.
-Another user said that he was confused about all the fuss concerning the conjecture of Sony's ability to provide pure LO, indicating that generally Sony's DAPS are rated for 0.3Vrms and therefore should be technically capable of providing a signal to the vast majority of aux inputs safely through the HO.
-More 3rd party confirmation that the nw-a45 HO/3rd party cable going into an external amp sounds superb from a few sources
For what its worth I just ran a HO of my n55 into my desktop speakers. They are audioengine 2 clones I got for very cheap that are surprisingly competent on a pair of iso-acoustic stands so I am able to discern the difference between different sources quite easily. I am running the output on 115/120 given this is usually the level I will be using when I drive my dt770 250ohm beyers. Amazingly enough yes the n55 can do that..... although I would certainly not recommend the n55 as a main driver for any kind of high impedance headphones, however the reality is the 6s falls to pieces on those cans, whereas they at least maintain perfect composure from this device albeit without great power. Anyway that is besides the point. I am going through my reference material right now on my powered speakers and the n55 sounds better than my 80 dollar dac/amp (dilvpoetry dac x-6, still a really good dac but very bass heavy and not the cleanest), and also the fiio e10k. I didn't expand on sound in my initial post but I would have to say the Sony has world class presentation in their sound. Perhaps you do not like the 'expression' of the music or its shape, but the imaging, soundstage and control of the elements that compose a song is as good as any DAC I heard. So now in hindsight, I will probably get one of the 3rd party cables however I am unsure if I will ever use it, the results I am getting right now with the HO speak for itself.
have you tried line-out with car AUX?!
curious how it will perform..
Aevum
- May 15, 2007
Broke down, bought one from Hong kong from one of these shops what say they are in europe but take 2-3 weeks to deliver and the package arives from china
fragzone
No but I have been using it with a couple of my speakers, my desktop ones and my high quality wifi speaker (through the aux input). The more and more I listen the more I can appreciate the Sony sound. So clean and so tightly controlled. I am imagine it would sound superb in your car.have you tried line-out with car AUX?!
chaotic_angel
helo, is it safe to plug directly A55 HO to an active speaker? considering the AUX 3.5mm jack have static shock..
fragzone
completely safe, read my post on page 18 about HO on the devicehelo, is it safe to plug directly A55 HO to an active speaker? considering the AUX 3.5mm jack have static shock..
Krutsch
Speaking of MQA, TIDAL just released an updated Android app that plays their MQA Master tracks.
Listening to this now...
TIDAL Master --> Google Pixel 2 --> LDAC Bluetooth --> Sony NW-A55 --> Shure SE846-CL.
Sounds nice. Not sure I would be able to tell the difference between this and MP3/320 on the same setup.
No gapless playback, however…
5
507447
Guest
Hi everyone,
I was thinking to buy a NW-A55HN (or 56HN) from amazon.co.jp but everyone is saying that the UI it's in Japanese. Someone that has bought it from amazon could confirm this? Do you know a site to buy the A50 where the language isn't in Japanese?
Meder Bakirov
- Jun 2, 2016
Hi everyone,
AFAIK, you can change a region setting with a tool, mentioned in previous pages.
5
507447
Guest
But, you don't have to install a firmware itself. The player has in the NAND all the configurations for all the regions. The program simply tell the player that it's from another region and it will change the features automatically
You had Japanese firmware installed out of the box? Now after using the tool, do you have multilanguage UI?
Thanks a lot for the info
5
507447
Guest
Amazon.co.jp won't send the player to my country and I can't buy it from eBay because I have to pay too much taxes. I don't know what to do: buy the A40 or wait hopefully for a release of the A50?
Meder Bakirov
- Jun 2, 2016
You may use forwarder companies to send your item from Japan
