nampramos
Can someone help me figure out what I'm doing wrong?
Just loaded my A45 with a DSD128 album but it isn't showing up on the player at all.
Loaded it the same way I did with other albums (which aren't DSD128). Connect it to the Mac, drop the new DSD128 album folder inside the MUSIC folder on the microSD card and that's it.
Shouldn't the A45 support DSD128?
The album has the following specs:
Samplerate: 5644800 Hz / PCM Samplerate: 88200 Hz
Channels: 2
Bits per sample: 1
Bitrate: 11290 kbps
Codec: DSD128
UPDATE: I have been able to play this album if I transfer the folder directly to the internal memory of the A45. But when transferring to the microSD card, it shows up the folder but says it has zero files inside. I have other albums on the SD card and they work fine. What could be the problem? I tried transferring other albums to the SD card and all of them have the same problem. Folder shows zero files.
Channels: 2
Bits per sample: 1
Bitrate: 11290 kbps
Codec: DSD128
