SONY NW-A20 SERIES
Oct 30, 2016 at 2:03 AM Post #362 of 430
Hey Guys,
A25 noob here. I just created a bunch of playlists in widows media player and synced them across to my a25. The music has synced but is says I have no playlists. Sure my old 1060 took the playlists from media player, a, I doing something completely wrong? Using windows 10. Would appreciate any help
Oct 30, 2016 at 7:31 AM Post #363 of 430
Hey Guys,
maybe A25 doesn't support that playlist format? What format it use? I suggest you make playlist using foobar2000 and save it in .m3u8 then copy it to A25. Or maybe you have to use folder view and search where you put your playlist? My X1 behave this way. Playlist tab only used for playlist that is create on the player.
Oct 30, 2016 at 10:53 AM Post #364 of 430
Hey Guys,
itunes.xml
Multimedia.m3u, .m3u8, .pls
Windows Media Player.asx, .wpl
Nov 3, 2016 at 2:54 PM Post #370 of 430
question for you guys,
Between the A17, A20 and AX100 which would you recommend? A17 $230, A20 $400, AX100 $700 i'm using them with Bowers and Wilkins P7 headphones, Shure SE530 and Grado SR80 (with Fiio E18 Amp). I'm wondering if the $170 price difference between the A17 and the A20 is actually worth it if NC is not really necessary.
Nov 3, 2016 at 3:26 PM Post #371 of 430
if you look better online now zx100 is under 500 US, but if you are still budget tight you can choose A20 or A10 which are basically the same, only diff is that a20 offer Noise cancelling in-ears
Nov 3, 2016 at 3:28 PM Post #372 of 430
Nov 4, 2016 at 12:21 PM Post #373 of 430
Thanks! at home i have denon X3000 receiver that can handle 24bit192 direct playback from media server but for portability I'm in love with aptX cause it does sound great and i don't think there will be much difference between the AX100 and A17 when using aptx as that would be the limiting factor. Also because i was able to pick up the A17 from best buy brand new for $40 ($240 actual price but won a $200 best buy reward so used that) so i don't think that price can be beat...
Nov 9, 2016 at 12:04 AM Post #374 of 430
The Sony shop in Auckland has a $199 limited sale on the A25
