Here is my thoughts after 40 hours or so with the MDR-Z7M2 and what I found effects the performance of these headphones. I wanted a good pair of closed back headphones for my home office that I can play at any volume if I want for late night Netflix or audio. After exhaustive reading I decided to pick up a pair of MDR-Z7M2. This was not a need, but I thought would be a fun project. I am more familiar with higher end home systems (theater and 2 channel), only vaguely familiar with headphone setups. I have listened to friends (only way lately because of Covid) Focal closed back (lower priced one), Audeze LCD2 Closed back and a Sennheiser HD820, neither wowed me or made me want to buy them. I now wish I could try the Sony Z1R.
After a few minor tweaks (see below) and for the price these headphones are very impressive. Originally after getting the MDR-Z7M2 I tried them from a iPhone 12 Mini and desktop PC with Audioquest Dragonfly Red, Cobalt, Ikko Zerda and straight from a iPhone 12 Mini and straight from the PC ASUS motherboard Realtek headphone output. Source being mainly Tidal (iPhone and PC) and Netflix (PC). Also tried using Motherboard DAC to a Grado RA-1 and a upgraded Grado RA-1 clone amps. Felt the headphones had potential and ended up with this setup: Source being mainly Tidal and Netflix from PC -> APO (Peace) EQ -> USB (will try toslink soon) to Schiit Modius -> Musical Fidelity X-10v3 (fully upgraded) tube line stage/buffer -> Schiit Asgard 3 -> MDR-Z7M2. I included a pic of the setup.
Here is what I found so far to make the biggest difference in regards to performance of these headphones (not in any specific order of importance):
1) EQ! From factory without EQ for me the frequency response was too flat. There is a peak in the 3K - 4K region that needs to be managed and below 200hz to 20hz needs boosting. When EQ is used these cans in lower to sub bass can emulate a powered sub in a home system without bleeding into mid base and midrange region. Basically it feels like I have a JL Audio powered sub on each side if I want, this transforms these headphones for me. The MDR-Z7M2 take to EQ well.
2) To tighten the bass and get more bass articulation from the MDR-Z7M2, inside of the ear cups need to be filtered or surgical taped like in the mods used on the MDR-Z7. I tried using a few different material like coffee machine filters and such and ended up using 3M Micropore surgical tape I picked up at Target. This tweak will make the overall presentation more coherent, slightly better separation of all sounds and get rid of the boominess in the sub bass. By the way, after the pad is removed 8 small phillip head screws secure the back cups.
3) I changed the stock pads for larger, more angled sheepskin pads. Purchased from AliExpress, took 20 days to arrive after ordering and was about $22. Changing the pad is easy, one small phillips head screw per pad and the pads turn and pop off. These are the 100mm pads found here:
https://www.aliexpress.com/item/33057605882.html?spm=a2g0s.9042311.0.0.426d4c4dzZ5xGE
And actually this YouTuber nailed it when he was describing what the pad change does:
4) The stock cable works, is flexible and is 10'. The stock cable holds these headphone back. I have a decent amount of experience with cables used in higher end resolving gear but not headphone cables. So the design is a tad of a guess but the sonic results were excellent, huge difference compared to the stock cable. For those who care, I used a Furutech 1/4" plug and gold plated copper mini plugs, WBT solder (FYI Cardas Quad Eutectic will give a slightly warmer signature vs WBT), JPS Labs Alumiloy 22ga. stranded conductors, 18ga. teflon tubes, twisted pairs, one for each channel. Then teflon tape wrapped the twisted pairs before inserting into techflex. This is where I realize after I should of used Fiberglass cloth sleeving instead of the techflex. The techflex if rubbed will be slightly microphonic. I may just order the Fiberglass sleeving from Sonic Craft and replace the techflex. Compared to stock cable sounds much more organic or real and natural. Way more micro and macro detail, vocals are not recessed like they were before, the difference between the cables are not subtle.
5) The MDR-Z7M2 can be run off a phone or a portable amp/dac like a Dragonfly but to really hear the potential of these headphones they need power. Performance will scale well with better amp and dacs, to what level I am not sure. As a side, it is clear to me that although good sounding inexpensive headphone amp and dacs are available they do not control EMI or RFI as well as higher end gear. These lower priced amps and dacs like the Schiit Audio stack I have perform astoundingly well for the money "after" EMI and RFI is addressed. Still tinkering with this.
Great headphones for the money, especially after 1-5 above.
