SONY IER-Z1R
post-15988644
Post #9,256 of 9,637
Damz87
Australia
Australia
post-15988657
Post #9,257 of 9,637
terminaut
SoCal
SoCal
I rotate them all depending on the mood :D but my plan is to eventually downsize the collection to 3-4 IEM’s, with the Z1R being one of them.
Ideally I would like a collection of IEM’s that are each specialists in bass, mids, and treble respectively, plus an all-rounder/reference type of monitor. However they all still need to be able to perform as an all-rounder to some degree as well. I know, it’s a bit weird and OCD lol...
So at the moment my top 3 would be Erlkonig for mids, Z1R for treble, and LXSE for bass. If the LXSE didn’t exist, the Z1R would cover both bass and treble :)
Interesting... Thanks for that!
Reactions: Damz87
post-15988896
Post #9,258 of 9,637
terminaut
SoCal
SoCal
Since I recommended them, I sincerely hope that this eartips will work ideally for you as well. Personally I don’t mind spending some money on well reviewed eartips as they are one of the most crucial component to extract best possible SQ. I mean I spend thousands of $ for these fancy pansy cables which yield relatively small sum of sonic benefits.
Based on your posts here I bought a set of large Eartunes and they are now my favorites. The fit/seal is perfect and seems to have brought about more punch with the bass and low end. I'm listening to old Elton John (Madman Across The Water in DSD) and the drums are just phenomenal.
I used to really like the Sennheiser oval tips on my ie800s so was happy to learn about these as they are very similar.
post-15988907
Post #9,259 of 9,637
aaf evo
Houston, TX
Houston, TX
All I can say for any future and new owners is really spend time tip rolling for the best comfort. I am using a ML on my left ear and S on right, for reference on the erlkonig I use S on both.
Great seal on both and much better comfort for my left ear versus the S. No noticeable sound imbalance either.
post-15989206
Post #9,260 of 9,637
excelion
Hong Kong
Hong Kong
@tgx78
The eartips had arrived unexpected early this afternoon, the M size fit perfectly for my ear canal.
@normie610
M size should fit you as well.
I do the measurement of the missing diameter information, for the M size it is 10.5mm width x 13mm height x 8mm tall.
post-15989212
Post #9,261 of 9,637
musicinmymind
I do not any tips, if mix size is not sold as pack.
It take bit of experiment to find right size and it varies with IEM, not sure Eartune does not sell mix pack.
post-15989481
Post #9,262 of 9,637
AudioMoksha
IND/AUS
IND/AUS
I haven’t had great experience with narrow bore tips either (sq wise) on the Z1R even the stock tips... I’d highly recommend trying out some wider bored tips (Sedna light short or acoustune AET07 for silicone or symbio F’s for foam).
Ordered the Symbio F foam tips. Thanks for the suggestion, now waiting for them to be delivered. Should be here in 2-3 days.
Reactions: Tristy
post-15990349
Post #9,263 of 9,637
tgx78
Vancouver, Canada
Vancouver, Canada
Website
www.jimpark.ca
Crin wasn’t kidding when he said you need a deep insertion depth with the Z1R.
I simulated this with my couplers and found wildly different frequency responses depending where the eartips were sitting. (Shallow to deep)
All three graphs were plotted with the Eartune fidelity U eartips.
post-15990363
Post #9,264 of 9,637
terminaut
SoCal
SoCal
I did observe more treble as insertion depth increased my ear. I'm not sure if it's the Eartunes doing that or if it's just the nozzle going further in. Here's my setup:
post-15990366
Post #9,265 of 9,637
tgx78
Vancouver, Canada
Vancouver, Canada
Website
www.jimpark.ca
drooling over that cable 😆
not sure if horn shaped eartips might be another contributing factor.
post-15990378
Post #9,266 of 9,637
terminaut
SoCal
SoCal
Haha I wish I didn't like its sound so much as it would save me some money and grief from the wife. She can't even relate to more than a couple hundred dollars to "listen to MP3s" lol.
Reactions: Sp12er3
post-15990546
Post #9,267 of 9,637
Ocelitgol
Previously known as stormers
NYC
NYC
dammit....now I have to ask...what are those eartip setup?
I'm looking for ways to make the Z1R more comfortable (not that big issue for me, but still)
post-15990559
Post #9,268 of 9,637
genck
Banned
US
US
Pretty sure the Z1R has more eartips in the packaging than any others I've ever seen? I don't own one but that huge selection of tips should make it pretty easy for 99% of people.
How uncomfortable are we talking here? Just curious?
post-15990580
Post #9,269 of 9,637
terminaut
SoCal
SoCal
I'm sad to say I don't know where those "stabilizers" came from as they were in my box of stuff I'd acquired over the years.
The heavy shells on the Z1Rs tend to droop into a position that makes some of the IEM's edges press uncomfortably against my ear lobes so I've experimented with various ways to mitigate that, and luckily this setup seems to work well. If I can figure out what IEM/earbud they came from I'll follow up.
Reactions: Ocelitgol
post-15990581
Post #9,270 of 9,637
Ocelitgol
NYC
NYC
They did provide a very generous selection of tips, that's for sure. But everyone's ears are different. While I'm not uncomfortable with them, if there's a chance I can make it better, I will jump to it :)
My problem with it just mostly the size, not the tips, but who knows. I can deep fit it though.
Users Who Are Viewing This Thread (Users: 1, Guests: 4)
