SONY IER-Z1R
Jan 19, 2020 at 12:14 AM Post #6,346 of 15,263
I know, but this was just my most recent test. Previously I was using a class A tube amp which can make the MDR sound magical and some Elektron synths all w/ plenty of power. I tested the MDR and IER w/ the ZX300 just to try and rationalize the divergent views on each.
Also too which can be confusing.............the choice of firmware. I’m guessing 3.01 was the last update ZX300 software. And while the ZX300 and other DAPs have a slightly different sound quality, 3.02 made the 1Z a very different animal with the IER. Surprisingly for my ears the TA darker with the IER, but has enough power to drive the MDR well. With the TA darker it’s also maybe slightly smoother with the top end of the MDR. Still 3.02 is so midcentric with the 1Z that it kind-of sideways the issue of making a DAP with less power try to drive a full-size headphone. It’s like 3.02 actually also works better with the 1Z/MDR combination as the firmware has less bass, so it’s asking the amp part of the DAP to produce less bass, which keeps it more aligned with it’s abilities.
Still in the end trying to do side by side of the MDR and IER....the Sony TA-ZH1ES is a good choice as it’s quiet enough for IEMs but loud enough for full size. Also surprisingly the TA offers a blacker background and better imaging for the IER. Though once you hear how 3.02 makes the IER with a DAP, you always remember that tone is a desired feature over technicality.
Jan 19, 2020 at 8:26 AM Post #6,348 of 15,263
Jan 19, 2020 at 10:44 AM Post #6,349 of 15,263
Sound stage , details , mids , bass , treble , tone , depth.
So in your opinion the JVC does everything better than the Sony ?
Jan 19, 2020 at 10:48 AM Post #6,350 of 15,263
The Sony is close , what I do like is that the Sony is easier to put on (in , insert).
Jan 19, 2020 at 11:15 AM Post #6,351 of 15,263
I just looked at JVC's response on Crin's website. It does look to have a good tonality. The bass however is interesting, it's very linear than anything I've seen(ER4SE like low-end) How does the bass sound on the JVC?
Jan 19, 2020 at 11:16 AM Post #6,352 of 15,263
I just looked at JVC's response on Crin's website. It does look to have a good tonality. The bass however is interesting, it's very linear than anything I've seen. How does the bass sound on the JVC?
Layered , goes deep.
Jan 19, 2020 at 12:24 PM Post #6,353 of 15,263
In general I am agreeing with Jmills8, the Z1R is a little more realistic than JVC however. The JVC does need a good clean and tight cable, otherwise the image can be a touch loose with stock cable. I own both at the moment.
Jan 19, 2020 at 12:34 PM Post #6,354 of 15,263
I will get tomorrow my Z1R
So I wanted to clarify which cable type is best suited for Z1R? Copper or silver?
Jan 19, 2020 at 12:37 PM Post #6,355 of 15,263
Get a fast cable, the dynamic will increase with the Z1R and that usually means silver.
Jan 19, 2020 at 12:41 PM Post #6,356 of 15,263
What about treble with silver cable? Usually silver adds more air and brightness. When I listened to the Z1R demo, it seemed to me treble sometimes harsh
Jan 19, 2020 at 12:48 PM Post #6,357 of 15,263
The good silver cable with very high purity silver should not add harshness to the treble but they tend to be higher in price. You can cable roll to see what you like. Norne, DHC, Effect Audio etc. one stock cable that I think you should try is the Final Audio latest stock cable they use on their A8000, should not cost too much, I think it is an OFC SPC cable and that shouldn’t add any brightness.
Jan 19, 2020 at 12:51 PM Post #6,358 of 15,263
Try the stock cable for a while before buying, the stock cable is actually very good
Jan 19, 2020 at 12:59 PM Post #6,359 of 15,263
Is this cable the same as for Sony IER-M9?
I have M9 and replaced this cable with ALO Audio Pure Silver Litz. It was an upgrade by sound for me
Jan 19, 2020 at 1:02 PM Post #6,360 of 15,263
I don’t know
