Sony IER-M9 impressions thread
5 6 7 8 9 10 11 12 13 14
16 17 18 19 20 21 22 23 24 25
  1. Raketen
    It's just a shallow-fit IEM, plenty of IEMs have used this style- It's a conscious design choice and they have been tuned accordingly. Unfortunately some shameful people dare to have ears that do not meet Sony specifications and are able to insert them deeper than is good & proper.
    twiceboss likes this.
  2. DynamicEars
    I have Final Audio E eartips too, good seal but narrow bore (narrower than sony silicone) made mid bass a bit boomy (just a little bit if you dont mind).
    Sound wise, sony silicone is the best IMHO, I think sony engineer tuned the IEM with reference to use with provided eartips since their eartips arent crap like some chifi tips.
    I still have them from EX1000, but they only comes in 3 pair of sizes L M S. Actually I made tutorial few months back for spiral dots with comply foam. You can fill in the sony silicon with memory foam too.
    and yes I also prefer shallow insertion for most of my IEMs, a bit feel itchy inside there in my ear canal if i insert them too deep.
    definitely +1 for this
    Mal Waldron likes this.
  3. Mal Waldron
    You're all right. Finally, I think I've got a proper seal with Sony hybrids LL so I'm going to buy two packs of SONY Hybrid EP-EX11 on eBay. The second hand EX1000 I bought didn't come with hybrids on that size so I only use them with Spiral Dots. I wonder now if these Sony tips will also be more appropriate for the EX1000 themselves.
    An absolutely amazing IEM. And yes, I consider them a breakthrough regarding my beloved EX1000 (also the JVC FD02).
    CoryGillmore and DynamicEars like this.
  4. PointyFox
    I can't get a good seal with any of the hybrids. Only the silicone LL and L work for me.
  5. anarch1st
    lol, everyone is mixing up the terms and getting confused here. Unless it's just me...
    When we're talking about Hybrids, we're referring to Silicone (as Sony evidently calls them Silicone Hybrids!). When we're talking about the foam-like tips they include, we tend to use TC for Triple Comfort.
    CoryGillmore likes this.
  6. Mal Waldron
    Hehe, that's it. At first I confused both tips. Hybrids LL are my choice. Listening Conan The Barbarian OST... Stellar sound, level of details and transparency not known to me
  7. DynamicEars
    Yeah thats correct
    Sony Silicone Hybrid = silicone look alike, they are claiming using mixed materials
    Sony Triple Comfort = Foam like eartips from sony that included in the package
  8. justsomesonyfan
    no i meant like... which specific one. there are 3 different white ones and 1 black. 1 normal white, 1 weird white, and one very long white.
  9. PointyFox
    Ah OK.
    Only the hybrid LL and L give me a seal.
    None of the TC do.
  10. twiceboss
    this
  11. Mal Waldron
    Heavenly bass... :ok_hand:
  12. justsomesonyfan
    damn i thought u were talking about the long one at first, do the others sound as good or are they straight up bad?
  13. twiceboss
    havent try them yet! But the bores seem like same size. I will do that later!
  14. bibit69
    Tips from MH750/5 still the bestest for me.
  15. twiceboss
    If you like bass, yes. If you like mids and clarity, symbio peeled is so damn good so far.
