Sony EX1000 Review and Impressions Thread (with comparisons to FX700, GR10 and e-Q5)
Mar 3, 2017 at 7:11 AM Post #3,228 of 4,748
Custom made, or use a adapter with a existing balance cable.
Mar 3, 2017 at 7:21 AM Post #3,230 of 4,748
Mar 3, 2017 at 7:29 AM Post #3,232 of 4,748
Taobao china.
Any link?
I tried looking before and had mixed / non results
I don't have the link anymore, once my transaction went through, I clear all records, and I have problems with the site, as I don't understand much chinese. They don't send anywhere outside china, I had problems getting it to Hong Kong.
Mar 3, 2017 at 7:32 AM Post #3,233 of 4,748
Mar 3, 2017 at 7:57 AM Post #3,234 of 4,748
  Oh, I had it saved in my internet browser.
https://item.taobao.com/item.htm?id=531625262975
 Thanks
Mar 3, 2017 at 8:02 AM Post #3,235 of 4,748
 Thanks
Before you get one, if you can, the resin one, doesn't last long, the thread does come loose if you twist too much, the last two photo is the result, but it isn't a bad thing, without the thread it does have a tight fit just by pushing it in.
The brass one has a tight fit, so I had to files the thread a little, but still can't get it to fit in the EX800, fits the EX600 as shown, and the EX1000 should be the same as the EX600.
Mar 4, 2017 at 7:31 PM Post #3,236 of 4,748
Dug out my EX1000 tonight. From the Aune M1S with a silver balanced cable, they are amazing.  I had forgotten how good they are.
Mar 4, 2017 at 7:36 PM Post #3,237 of 4,748
Mar 10, 2017 at 5:16 PM Post #3,240 of 4,748
Going to pick a set of balanced cables for my EX-1000's.  Seeking opinions as to whether I should get copper or silver.  Supposedly cooper is warmer.  I have a ONKYO DP-X1 that I use with my EX-1000's.  So what do you think, copper or silver?  Does it really matter?
Opinions appreciated,
john
