Originally Posted by HiWire
Hey hifiboom,
It looks like your player may have optical out... if you can swing extra dough, the new Headroom Micro DAC or something like it may be able to pull better sound quality out of your red discus. I don't think the North American versions have this extra jack.
Good luck in your search for earphone synergy.
thank you HiWire, just tested the optical output and recorded the result with Sony Soundforge under WinXP. It does work fine. And it is a native 1:1 optical output. I mean it is not normalized volume to 50% or something like that, So your DAC Amp would work fine, but I won`t spent another 300 $ on my portable audio to make it as hard to transport as a regular standalone CD player with full headphone output for 100$.
Maybe i`ll just go and buy an iAudio M3 or the newer one with 20GB.
I want a portable device with good soundquality and good batt life ( but ~10h are enough for me) I don`t need 100hours... as the sony can do.
I like the sony very much, but I miss a little bit more soundquality, my neighbor has an iPod shuffle and not exactly sure but it is sounding better than this sony model ( but I just did 5 min comaring both ).
I don`t need the best audiophile headphone output, but I need something more brilliant than this Sony....
I`m sure if I buy the iAudio I will be satisfied....
or should i go with iPod?
I don`t want any AMPs !
That doesn`t fit my idea of a portable device. you need extra batts for the amp too, Thats a noGo for me.......
And I want one unit and not 2 or three.
