Nomi
- Dec 6, 2002
Hi, I just received a D-555, everything seem to be in good order, except the AC adapter has few knots and a replaced connection tip. I put in a CD and immediately notice the right channel is much louder, the vocal and bass is on the wrong side of the channel(they should be a little to the left of center). I check the line out and the sound there is fine. I continue to try few more CDs and the results are the same. Are your D-555 like that, they vocal and bass lean more on the right channel? I think there is something wrong with my D-555. How could this be possibe. Is there any thing I can do to fix the problem. Will it cost alot to fix it. Thanks for any idea or suggestion.
