Sony A810 vs S638 vs S738
Nov 27, 2008 at 9:27 PM Post #16 of 22
DaGreatAzn
I see that hiss is a big issue, but is there a difference in sound quality besides the hiss?
Nov 28, 2008 at 10:29 PM Post #18 of 22
fredman22
Originally Posted by Ihatepopupads /img/forum/go_quote.gif
Only on sensitive iems , UM2, shure e530 ect.
The above is true, but it will vary - I can hear a white noise that might be categorized as hiss, but I have to listen for it and it is not audible during music - but it is there (A829/UM2). No doubt the intensity is dependent on your hearing ability as well (mine's probably so-so..). The noise is entirely absent with my cans (CD3k, CD780) or Ety4Ps. I had read that hiss was more noticeable with the A71x/A81x (there was an engine upgrade between A71x/A81x and A72x/A82x models) but have not really heard direct comparison testimony between A72x/A82x vs. S63x/73x - still only speculation at this point. If you plan to do any semi-serious listening with your DAP with higher end IEMs, I'd consider bypassing the older A81x: SQ is definitely upgraded in the A82x and will be the same or possibly better in the newer S63x/S73x. Good luck.
Nov 29, 2008 at 10:06 AM Post #19 of 22
dura
I hear no hiss listening to ATRAC on my A808 (same as the A818) through shure E4s or cheaper dynamic IEMs, nor on the px100, but it might be my age.
Nov 30, 2008 at 5:30 AM Post #20 of 22
ShootingStars
hiss not big issue.
i have the s639f, EQ is simply amazing - especially if your phones are lacking or have too much of this/that
SQ is GREAT
surround are cool
wallpaper function rocks! you can put hot pics... winkwink
long batt life
Nov 30, 2008 at 6:07 AM Post #21 of 22
K3cT
Just get the newer generation and be done with it though I notice no significant SQ improvement whatsoever.
Nov 30, 2008 at 3:40 PM Post #22 of 22
abitdeef
Formerly known as ihatepopupads
You won't notice any unless you have very revealing cans or sensitive iems. The hiss on my a818 was quite apparent on my e530's, but on the s639 they are very quiet, as long as you don't turn the eq on
Also the high end sounds a little smoother than my a818. Not night and day by any means, but with the e530 I really appreciate the s639 sound sig. The hiss and the little edgy highs of the a818 were my only complaints and this seems to have been fixed with the 639.
