Sony 53" Screen TV problems!!! HEEEEEELP (sorry if im in the wrong part of the forum)
Sep 4, 2003 at 6:36 AM Thread Starter Post #1 of 15
seis66
Hello everyone of you!
Man, oh man, I have this mission for all of you guys.
About 3 years ago my dad bought a huge home theater (Pioneer VSX-456 reciever, Technics SL-MC401 111CDs charger, Technics SH-GE70 EQ and amp, Technics RS-TR272 deck, 5.1 bose system (dont remember the model, but Ill be looking at the manuals) and some Technics Loudspeakers (dont remember de model either).
We mainly play PSX and watch DVDs and some Tv here.
Now here comes the problem (photo attached)
WHAT CAN I DOOOOOO
Any kind of help will do.
Thanks
Walter
Sep 4, 2003 at 7:19 AM Post #3 of 15
its ok. I dont need you to speak in spanish. I do understand everything in english
Walter
Sep 4, 2003 at 2:09 PM Post #4 of 15
You've got a badly converged set. If the set has a flash focus button, now would be a good time to use it. In theory it should restore the Sony to its proper convergence settings. In practice this may not work. In that case, someone is going to have to go into the service menu and converge the set. If there's an extended warranty on the set, this should be covered. www.hometheaterforum.com may be useful. If the set is high-definition capable, there's a sonyhdtv group on yahoogroups.com, but they charge for membership these days. Lots of info there, though.
Sep 6, 2003 at 5:24 AM Post #5 of 15
I´ve just sent them a post, but the just dont answer
Can someone please help me?
Sep 6, 2003 at 7:59 AM Post #6 of 15
Hirsch is right, I might just be a convergence problem. My sony has an auto-converge button right in front of the set. Yours may have one too.
My next guess is that you may have an unsheilded center-channel speaker right on top of your TV. Try removing your center channel and see if this fixes the problem.
Good luck
Sep 6, 2003 at 2:05 PM Post #7 of 15
The CRT's in a 53" Sony are in the base. A speaker on top isn't going to produce that effect. All that's happening up there is light reflecting off of a mirror, and a magnetic field won't bother that one way or another. Even an unshielded speaker is far enough away from the CRT's on top of one of those.
It's actually the norm for a set to require reconvergence after a couple of years of use.
Sep 6, 2003 at 5:29 PM Post #8 of 15
Well, my dad leaved a center speaker on top of the TV. We thought it was that about a year ago, so we took the speaker down of the top. Nothing Happened. Can someone please tell me wheres that "magical button" that you talk about?
Thank you so much
Walter
Sep 6, 2003 at 9:44 PM Post #9 of 15
Thank you so much
Walter
It will depend on the model and year of your Sony. Some sets might not have it, but in that case you should have some manual convergence instructions. On my set, it's on the front control panel. It's a small square button on the bottom of the panel.
Sep 6, 2003 at 10:25 PM Post #10 of 15
It's most likely an internal hack. i have a few pages for my XBR on how to go in and manually set everything. I don't see what the worry is. Most likely it's the tv's fault... unless you were messing around in Service mode. If you can't find it call da tv repair man!
P.S.
That center speaker on top... was it shielded? How close are the other pictures to the tube. If they're close get them away immediatley.
Sep 7, 2003 at 10:56 PM Post #12 of 15
Well, I turned my TV down. The model n° is kp-53s65c.
Any new ideas?
Thanks
Sep 8, 2003 at 1:56 AM Post #13 of 15
Here are manual convergence instructions from the Sony site:
Follow this procedure to adjust the television convergence settings.
IMPORTANT: Some Sony® televisions have a Flash Focus or Image Revision feature and do not have manual convergence settings. Consult the instruction manual for model specific information on these features.
Turn on the television.
On the remote control, press the MENU button.
Press the DOWN ARROW until the SET UP [FIG. 1] menu is selected.
Press the SELECT [FIG. 2] button.
Press the DOWN ARROW until CONVERGENCE is selected.
Press the SELECT button.
Use the ARROW KEYS to select a color.
Use the ARROW KEYS to align the color with the other colors on the screen.
Repeat steps 7 through 10 until the cross pattern on the TV screen is completely white.
Sep 8, 2003 at 12:52 PM Post #14 of 15
Well, I dont this it a problem of convergence. Im really thinking my TV got ruined somewhere, because Ive tried the "convergence" regulator, but it doesnt show any proven changes.
I saw theres a "service menu" for Sony TVs. Anyone knows about it?
Walter
p.s: Hirsch, If I got to thank someone in most of my questions in this forum, that is you!
Sep 8, 2003 at 2:12 PM Post #15 of 15
Walter
You're welcome.
The service menu is the place to go if you want to screw your TV up REALLY badly. I'd strongly advise against attempting it unless you have the service manual for the set. You'll have to enter a string of commands on the remote to get into the menu, but the settings will be meaningless without the manual to decipher them. I don't know the commands for your model to get into the menu, but hometheaterforum or avsforum might have info.
However, the best advice I can give at this point is to have a technician diagnose your set. If user convergence controls won't align the CRT's, it may be time to let a professional figure out if there's a hardware issue.
