Some suggestions for a receiver and speakers for my PC
Discussion in 'Computer Audio' started by d34dj3d1, Jun 4, 2018.
  1. d34dj3d1
    My budget is $150-$300 for the Receiver and the same for the Speakers.
  2. PurpleAngel Contributor
    For your budget, you could get a pair of studio monitors and a sub-woofer.
    https://www.monoprice.com/Category?c_id=115&cp_id=11504&cs_id=1150401
    Are you looking for bookshelf speaker or towers?
    Check the websites Slickdeals and Techbargins for audio products on sale.
    My two cents, modern A/V receivers seem to get better ampilifers when the receiver retails for over $500.
    So maybe look at buying a slightly used receiver (off Craigslist)
    or a refurb from accessoriess4less
    https://www.accessories4less.com/ma...-ch-x-90-watts-networking-a/v-receiver/1.html
    For your over all audio budget, I think your better off spend more for the speakers, then the receiver.
  3. PurpleAngel Contributor
    You might try asking about receivers and speakers on the websites AVSforum and AVforum.
  4. d34dj3d1
    Bookshelf either 2.1 or 5.1
  5. PurpleAngel Contributor
    As this is for use with your PC, can't see a good reason for buying a receiver and (un-powered) speakers.
    Maybe buy JBL LSR305 studio monitors ($300 for the pair) and a (Monoprice, $220) sub-woofer (make more sense).
  6. nvfan
    Elac B5 and some used receiver (craigslist/ebay) ?
  7. KungFuNat
    What do you need the receiver for? I would get a set of Klipsch promedia 2.1
