solved: help fiio e07k vs e17 vs e18 vs x3 my head hurts
post-10653005
Thread Starter
Post #1 of 5
Ninjiaw
hi i made a post a while ago looking for a dac/amp to pair with my hd558 headphones and was recomended a e07k or e17.
i  have found i can get an e18 for a simoler price as a e17 but have been considering getting an x3 and droping the dac/amp altogeather.
i was also recomendid  to save up for a better set of cans however i think a $280 pair of hd558 headphones to be fine for my use.
i am curently using an iopd touch 3rd gen and  was just rondering if i should get an x3 as a deadicated source vs using somthing like an e17.
edit: after doing some digging around i have found my answer.
post-10888600
Post #2 of 5
tyler555
Would you mind sharing your answer please and maybe an explanation.
post-10889304
Post #3 of 5
PurpleAngel
California
California
  hi i made a post a while ago looking for a dac/amp to pair with my hd558 headphones and was recommended a e07k or e17.
i  have found i can get an e18 for a simuler price as a e17 but have been considering getting an x3 and dropping the dac/amp altogether.
i was also recommended  to save up for a better set of cans however i think a $280 pair of hd558 headphones to be fine for my use.
i am currently using an iPod touch 3rd gen and  was just wondering if i should get an x3 as a dedicated source vs using something like an e17.
If this is for portable use, I would say to get the FiiO X3, everything you need in one small device.
post-10889540
Post #4 of 5
tyler555
I decided on fiio e07k so that I can doc it in the eo9k later and have the convenience factor of having one dac and not having to plug in and out cables when I want to use headphones vs speakers.
post-10904403
Post #5 of 5
Ninjiaw
sorry for the late responce i have decided than my ipod touch is fine enough for mobile use and that i will probably end up getting a schiit magni modi stack for home.
