sodaya
- Jul 5, 2004
This is a 'solution' post, if you were/are encountering trouble setting up the ASIO plugin with Foobar. Foobar kept giving me the error message:
"ERROR (foo_output_asio(dll)) : unsupported output data format."
After about an hour of changing settings and researching, I found the solution posted on hydrogenaudio. Which you can read here: http://www.hydrogenaudio.org/forums/...howtopic=29958
It turns out, you have to change output data format to "32bit fixed-point" in preferences->playback.
