Thanks dB. It's a Hammond 1402FV. The board fits in the side rails as well, but I wanted full internal mounting. It's more pricey than the typical aluminum and a bit bigger, and heavier since the top and bottom is pretty thick steel with nice front and back plates.
I was seriously going to go for the top mounting, but just couldn't make myself do it. The shades of yellow theme would play better in gradations of yellow/amber. I'm still keeping an eye out for a nice gold/amber 1/4" jack.
The power switch I got off e-bay from PartsPipe. It's a Bulgin imitation or copy, but it is the latching variety so the button depresses in and sticks. I have to hit it with my pinky, fat fingers apparently. I am using a wallwart and am using the DPDT switch to pull the 2 15V AC rails. There's no room in the case for a toroidal, after the PC board. It's illuminated as well, and takes a 12V input for the internal LED. I'm not sure if there's a current limiting resistor in it, there's no docs on this switch, but I had to use a 120 ohm resistor to get something that's at least visible in daylight so I presume there is. I didn't want to try a link, but I have a feeling it would work.
