Software problem @ Zen V Plus [Solved]
Aug 7, 2007 at 5:43 PM Thread Starter Post #1 of 2
Lpe_91
Hi Head-Fiers!
I bought a Creative Zen V Plus around christmas -06. It has worked very well, till a while ago. This player doesnt work as a usb-stick, e.g as a "removable disk". It has a software that you install, and add songs to the player with. Now the problem is, The Computer (windows xp) says the player is connected, but the software doesnt. That "dudun" sound is played when i plug the player into the computer, but the software still tells me to connect the player! What should i try to do? Has anyone else had this problem? Please, help me!
Edit: Nevermind, i solved it by installing windows media player 11
Aug 7, 2007 at 11:28 PM Post #2 of 2
I have had to reset mine once or twice, but the software has been stable for me and use it as a removable disk each week.
