sander99
This is only true for all headphone related outputs, but not for the 3.5 mm jack outputs. In AV mode only the 3.5 mm jack outputs are active. In "non-AV" mode all headphone related outputs can be active. Generally, if there is a headphone signal for user A it will be available simultaniously at the normal HP A 6.3 mm headphone output, the HP A analog cinch outputs, and the HP A spdif (coax and optical) outputs. Likewise for user B. (Except in balanced mode, then the headphone amps are bridged and both 6.3 mm jack outputs are used for user A, I don't know what the other HP outputs do then exacly).You could potentially use every analog and digital audio output at the exact same time.
(On the future features list is a hybrid mode in which headphones and 3.5 mm jack AV outputs can be used simultaniously, but if and when this ever will be implemented?)
That is correct. You could connect the analog HP A or B cinch outputs to an amplifier with speakers, or the digital HP A or B coax or optical to a DAC or amplifier with digital input.AV-in said that it's an interesting idea to use the stereo mixdown mode, that may allow me to plug the speakers on the HP-A output.
You can play the processed headphone signal over speakers but it will sound a little odd!Do you think I will have to manually disable all of those treatement each time I want to use the speakers?
The "normal" way to use the A16 with speakers is by using the 3.5 mm jack outputs that output pre-amp signals that can be input to power amps, integrated amps, or active speaker.
You should prepare one preset for this, with up to 4 listening rooms (one for each of the source formats that you use, pcm, dolby, dts, auro 3D). You need a PRIR indeed although it is not used in AV mode (and indeed doesn't affect the audio signal). That is a little odd of course, but not a problem because you can use any PRIR for example one of the factory provided ones. The main thing is that in each listening room the listening mode is set to 2.0 (in your case, wanting to use only 2 speakers), that way the A16 knows it has to downmix any input signal to 2.0.That means that even on AV mode, when the speakers works, a PRIR is needed? I guess it's just for internal processing and doesn't affect audio signal, right?
[Edit: oooh, actually I think I may have this completely wrong: I am not really sure the A16 will downmix if the source has more channels than the listening mode supports. Maybe it will simply ignore the extra channels.]
No. The user A volume control works on all HP A outputs including the spdif (coax and optical). Similar for B. Maybe a little different in single user modes, like balanced or 24 channel mode, but still always there is a volume control active.I think there is a static level setting, made for connect a DAC to the A16.
Normally to listen to 2 speakers you should switch to the preset (that I described above) AND switch to AV mode.Let's say I go the classic way with speakers pluged on the 3,5mm line outs, practically, how do you switch from a headphone multichanel setup to a 2.0 speaker setup? Switching PRIR (multichannel to 2.0) can be done via the remote? Then I need to switch from headphone mode to AV mode?
It is a little clumsy unfortunately.
But note: if you use a good personal 2.0 PRIR in that preset you can quickly switch between real and virtual 2.0 speakers by only switching on or of AV mode.
And when listening to a stereo source (without upmixing) it doesn't make a difference whether you are in the 2.0 listening room or a multi channel listening room.
Likewise: if you are in another preset with multichannel listening rooms and then switch to AV mode you will simply hear only channels 1 and 2 (front L and front R) over the real speakers. And again, if your source happens to be stereo (and no upmixing is used) it doesn't matter.
So only when listening to multichannel content the double switch (preset and av mode) is needed.
