dsperber
- Jul 27, 2005
Are you operating in 16ch mode, or 24ch mode?
Are you trying to use the optical stabilization? Since it says in the Firmware release notes for 2.11Is anyone using the User B head tracker?
The status of the head tracker(s) is reported by pressing the "HT" button on the remote just left of the blue "PB" button while the speaker map is displayed. Mine says "not detected" for User B (click on the photo). When I plug in the head tracker when the A16 is on, the HT screen flashes several status messages, including "warming up", the LED on the head tracker shows green for a few seconds, then turns red and the status changes to "User B HT not detected".
If I plug that head tracker into User A it works as expected. Plugging the User A head tracker into User B also shows "User B HT not detected".
Alternatively, can anyone using a single head tracker select the "HT" screen on the remote and then temporarily plug the head tracker into User B and report what the screen shows for status and their firmware level. I'm on firmware 2.05.
(Note - press the HT button a second time to return to the speaker map).
Yes, I am using optical stabilization so you've solved my issue. Now to experiment with other stabilization, wait for newer firmware, or just use only User A and just plug and unplug when I want to switch headphones. Thanks!Are you trying to use the optical stabilization? Since it says in the Firmware release notes for 2.11
New A16 Features in Development (all hardware variants)
1) Auro3D certification
2) Vertical Headtracking mode
3) Low delay gaming mode
4) Extend optical stabilisation mode to User B head tracking
The format button really only shows you all the bitrate options avialable for the amount of channels you have available to you. As for me, I can select from 16 20 and 24 bit at 48kHz, all at 2 channels.Don't press the configure speakers button. What does the "Format" select box (on the same page as the configure speakers button) show you?
I have had the A8 before A16, and I have done personal PRIR measurements with both. With A16 I use 3DSoundshops D&D (non personal) PRIR with manLOUD and it is awesome for movies and easily beats my own EQed HT setup 7.2.4 Atmos setup (NAD M17, Hypex Ncore amp, 2x SVS subs + 11 High efficiency Omega speakers, Class A amps for L + R + C channels).Yes, I agree. I must say that I just assumed that @KMann is using an in person PRIR already, if not then for sure he is not using his A16 anywhere near optimal!
[Edit: I was looking at some older posts by KMann and I saw he did personal PRIR measurements and manLOUDs, and put quite a bit of effort into that it seems.]
I also see something else I have in my home as well.A nice little article at Audiophilestyle about the MSM Studios some of you plan to visit for a measurement. There is an easter egg in this picture.
I came to the same realization.I also see something else I have in my home as well.
