I don't understand your logic here. All speakers that you measure in one go will first be measured for the first lookangle. Then all will be measured for the next lookangle. etc. So you never have to move back to the starting position. Until you start the measurement for the next few speakers. But then you would have moved anyway to make the required changes, or even use other head positions anyway (in the case that you use speakers in a fixed position and move yourself relative to the speakers). Except when someone else moves the speakers and changes the connections and you sit with your head in the same position during the complete process.
Apart from that: it really wouldn't matter much if some of the speakers are measured one or two degrees differently.
Huh, you know what? I wonder if my issue was a symptom of just having to use a 5.1 receiver when doing a 7.1 PRIR and needing to use the "ALL" mode. I have a really nice Marantz receiver coming, so I'll be able to see if that was the actual problem in a few days. With the way I previously had to do it, the A8 would not record each look angle for
all of the speakers in one go before having us move our heads left or right. The way it was working for me was with every individual speaker. So for the center, we would look center, then have to look left, then have to look right, then it would move to the FR and we would have to be centered, then look left and then look right etc. I was previously having to record 5.1 that way and then get up, and then change the output cable of the A8 for the rear surrounds before finalizing and saving. So do you now understand why I was questioning whether or not doing anything other than remaining center throughout the entire procedure, even when it was wanting use to look left or right mattered? In the end, it seems like needing to use that mode will be unnecessary anyway for future PRIRs.
The PRIRs that I ended up doing were not meant to be perfect "one and done" recordings either, they were primarily just me getting used to the procedure so that at a later date after I purchased the better gear I was intending to use, with a much better room, I wouldn't have to fumble around with the learning process, wasting time during that day. I did however want something that was good enough to show what the A8/A16 was capable of to myself, and friends.
I managed to get a nearly flawless 7.1 PRIR, but the front right ended up sounding "off" (like 85% accurate, but when the rest are 100% it doesn't sound perfect). There were many other problems though with other PRIRs, and I think it might have been due to the
old Denon receiver I was using at the time. With some of my recordings, the sound level of the rears or center would be around 10% - 20% of the volume as the rest of the speakers, and no amount of gain from the A8 menu would fix that during playback. I even contacted Mike Smyth to see if he could give me any insight into what the issue could be, but even he couldn't really manage to find a solution. I told him exactly what I was doing when having to use multiple speakers to get a 7.1 PRIR and how I was calibrating each time, and he said that everything I had written sounded correct, but that for some reason it wasn't working as it should. He also said that really the Center, FL+FR were the most important speakers to get, so to concentrate on getting those right. I had assumed that was the case anyway, but it was nice to hear it recited from an expert.
Hell, this is even in the instructions:
Through the speakers an announcer will say “Look centre.” The listener should look straight ahead with head level (not up or down, 0° elevation), and keep head fixed while each speaker is sounded in turn. In this basic procedure, do not look at the centre speaker if it is positioned above or below a screen; look straight ahead.
That's even demonstrated in the old video where Mike is recording a PRIR for someone.
It must be that I got so used to using the "ALL" mode that even when I did my 5.1 specific PRIRs we were still having to turn our heads for each speaker. So what is the default mode when wanting to capture all speakers at once then, including a sub? Does the A8/A16 just default to a basic recording mode each time it's turned on? What if you had to save the system config? I thought it kept your last selected recording mode when doing that.
