Dixter
- Dec 21, 2011
Ok... I went back through ALL of the settings and now I have the A16 setup in all modes to " Direct " input with no upmixing at all any where... now with the iphone hooked up through the HDMI adapter
playing back a movie ... it reports that the iphone is sending the data out in PCM Dolby Surround... so if you play a movie that is 7.1 then the A16 plays 7.1... or a movie with 5.1... then the A16 plays back 5.1... so that in itself is cool coming out of an iphone... and using the up arrow the A16 reports it correctly... what throws you off a little is that if you have a 9.1.6 PRIR loaded in the PCM slot then the up arrow reports that you are listening to 9.1.6 even if you are feeding the A16 with 7.1 Surround... you just need to go to the audio meter screen and you can see that 9.1.6 is loaded but populated by 7.1 or what ever processing for the movie you are playing back....
and with this setting when you play one of your music apps from the iphone then it feeds the A16 in 2 channel and plays back in 2 channel ... or the L/R speaker in a 9.1.6 PRIR...
and of course if you feel the need just turn on upmixing
so all is good...
so all is good...
