audiohobbit
It doesn't work exactly like with the A8.
From the manual p. 40:
So if you're in optical mode and your azimuth angle drifts wildly (i.e. your speakers move around you uncontrollable) plus the LED on the head top doesn't light up at all or never turns green (one of mine just flashed red periodically, the other one never lit up) please follow the procedure I posted in the other thread and linked above. This came directly from (James) Smyth.
The gyro is ALWAYS used. It is only periodically stabilised by the optical signal.The head-top device has three tracking elements: inertial (gyro), magnetic and optical. The inertial element is the primary
means of tracking the rotation of the listener’s head, with either the magnetic or optical elements being used to stabilise the
inertial tracking – i.e. to correct for inertial drift. The inertial tracker can also be used with no stabilisation.
The optical stabilisation requires a periodic pulse of IR light from the set-top device, whilst using magnetic stabilisation (or
NONE) does not require the set-top device. If magnetic stabilisation is used then the set-top device simply indicates that the
head-tracker is working and the approximate angle.
