Rene Lou
- Jan 21, 2014
The reason I have a 5.1 dolby setup as well is for my user 3 other family member profiles I only have made 5.1 for them as it's too hard to deal with 7.1.6 for them. So when I watch movies with them I have to pick the 5.1 profile to match theirs so sounds don't get lost. My understanding is user A room sets up the main decoder, and B gets the sound from the same channels that come from user A. So if user A has LSS and LB and no LS, then user B will hear nothing from the surrounds. So I have to downgrade my experience when listening with family members unless I find time to make them all a 7.1.6 profile.
Reason for this behavior is that the channels coming from the same MDS processor for both users. Those channels are fed into both SHARC DSPs in parallel (the SHARC DSPs are running the SVS rendering, e.g. creating the virtual speakers for user A and user B). There is only one Dolby/DTS/Auro processor (MDS) inside th e A16 but two SHARC DSPs for SVS processing:
- the MDS processor converts Dolby/DTS/Auro bitstreams into n-channel PCM and optionally upmixes (with the Dolby/DTS/Auro upmixer) to m-channels
The output from the MDS processor (n- or m-channel PCM) is fed into the two SHARC DSPs:
- SHARC #1 DSP runs SVS for user A
- SHARC #2 DSP runs SVS for user B (or Illusonic upmixer for user A to x-channels in an upcoming firmware)
Result: both users need to have the same count of active virtual speakers, or something gets lost.
If you would like to have two different sets of virtual speakers active for two different users with correct channel processing for both users, you would need a second A16.
Thanks to the capability of the A16 to combine virtual speakers from different PRIR files - instead of 'downgrading' your experience to 5.1 - you could 'upgrade' your family member PRIRs with missing speakers from the BBC room without the need to remeasure (eg: combine their 5.1 measured speakers with 6 dummy-head overhead speakers from the BBC room and the two missing rear speakers to get a 7.1.6 for them as well). Just as an interim-solution until you will get them remeasured.
