dsperber
- Jul 27, 2005
Back in early 2018, after I'd had my revelatory demo of the A16 + headtracker at CanJam SoCal I decided to start using it at my viewing/listening location where it was physically feasible to place the TV-located piece where it needed to be. So I tried to locate one (or both) of the two pairs of devices which came with the two A8's I have.
One of them (the 2009 original) was easily located, but the rechargeable battery (from 2009) had apparently totally died from non-use and age, and could no longer be charged. I inquired of Lorr if it was possible to have the battery replaced in it (by Smyth) and he said "not possible". Since that time I believe I've read that it is physically possible to pry open the HT and change the battery, but this isn't a service offered by Smyth. Nor did they have any "spares" for sale.
Asking if I could buy extra A16 HT's to use with the A8, he replied: "The A16 tracker is not compatible for use with the A8 set-top." This was in April 2018.
As it turns out I eventually found where I'd put the carton containing the second one (from 2013), and thankfully its HT battery could still be re-charged. So that's the one I'm now using, leaving it plugged into the related A8 for topping off when not actually being used atop my headphones.
So as of April 2018, per Lorr it doesn't appear that you can use an A16 HT with an A8 set-top unit.
