Chillzone21
- Nov 16, 2015
Checked the Realize Exchange website today and it had no studios/stores/venues local or otherwise listed. For me, a further reason to wait.
What is the link to that website?
5 weeks passed since the last email we got from James Smyth. An update would be appreciated... maybe something will come up this week... So far this year, we got an update at the end of each month (January, 29th - February, 28th and March, 31st), but not in April...
https://www.head-fi.org/showcase/review/8677/Link?? Sounds helpful.
I looked but didn't find it.
(At the moment I only get an error message if I go there, but there was something some time ago.)
I am a little curious if we can take the A8 files and load them into the A16 and if they will work... or we can edit the A8 8 channels to the A16 16 channels ...
probably wishful thinking on my part...
When did you get that email and what does it say exactly?In an email from a Smyth, I was told no backward or forward compatibility between A8 and A16 files.
(The other way round probably is not possible, I think that has to do with copy-protection/encryption of the new format or something like that, Stephen Smyth hinted at that in the innerfidelity video.)Files
(refer to the root menu screen) allow the user to manage PRIR and HPEQ files both within
the A16 and on the external micro SD card. The screen below provides a log of the file numbers for each
storage location. The screen on the right is an example file information window for PRIR files. In this
case this is the first file of 26, found on the external micro SD card. This particular file is from the old A8
Realiser model and will be automatically converted to the A16 format when copied into the A16 internal
storage.
Indeed, if we trust the 4 to 6 weeks period before shipping debutes that M. Smyth (i don't remember if it was Stephen or James) mentioned in his interview at Can Jam, it's been now 4 weeks already so shipping could be imminent... I'm just hoping that it's the case...
I assume shipping is close due to the lack of an end of April update. My thought is they skipped it because they knew shortly into May they could announce that the product was done and ready to be shipped (obviously could just be wishful thinking on my part).
The document http://www.smyth-research.com/downloads/A16 UI overview.pdf (came with the 14 Nov 2017 update) suggests that A8 files can be loaded (and will be automatically converted to A16 files).
Page 4:
And to come back to your question Dixter, because with the A16 you can create presets for wich you can select virtual speakers from different PRIRs, you can combine speakers from (converted) old A8 PRIRs with additional speakers from new PRIRs.
I agree. But in the worst case scenario that the A16 can not use or convert an A8 file you will have to ask Smyth to convert the file for you, they can do it for sure and in your case it seems to me they should do it, and do it for free.That information has to be incorrect
Even if Smyth will not convert it, it is technically possible to convert it via software that captures and reproduces impulse responses.I agree. But in the worst case scenario that the A16 can not use or convert an A8 file you will have to ask Smyth to convert the file for you, they can do it for sure and in your case it seems to me they should do it, and do it for free.
