jgazal
- Nov 28, 2006
(not phantom center for me, a real center channel).
Have you tried red book standard compact discs with stereo recordings?
The center and surround speakers are not supposed to be affected at all. Only the front left and right speakers are supposed to be affected, because you change the levels for those only. Even before you change the levels, all speakers should sound the same as before, and if they sound different in any way, the difference is being caused by something other than crosstalk reduction. Maybe both presets should be erased first to make sure they have all the same settings.This method placed the center channel close behind my head, (not phantom center for me, a real center channel). It also collapsed the surround channels and added driver vibration to them.
It worked for me with a regular PRIR. Being able to use any PRIR is a benefit of this method.I think you need to record the PRIR that way for it to work.
And of course use the same HPEQ for both users.Anything else I should know?
Indeed first try to make it sound the same as with the normal use of the PRIR (all speaker levels the same for both users, do a direct comparison like Erik described in the other thread).
I also check the thread everyday for news. Seems we need somebody in the inside of Smyth to write more hereJust checking to make sure this thread is still alive. Nothing for a week here.
So, this Smyth Realizer is still unrealized....?
