hi thanks a lot for the very kind and helpful reply
i got mine yesterday and i am playing files stored on a usb external Maxtor 1 Tera disk flawlessly great!
unfortunately i cannot control it with Hiby Music app could you please give me instructions about how to set the app up ?
i read about an icon to click on the right side but i don't see any
thanks a lot again gino
Browsing Music through the Small screen is really Awful, that is where Hiby Link came to rescue. Please remember you can't use the Bluetooth as a Music Source (Example: Stream Spotify From your phone to DP3) until you turned off the Hiby Link.
Below is the pictorial procedure (how to) :
This is how it looks when Hiby Link controlling the entire unit as a remote, It even control the volume of the player too. Paired phone/tablet's volume switch becomes the volume control of the entire music system.
Steps (1)
Go to the DP3 player home screen -> Network -> Bluetooth -> Hiby Link (make sure it is ON)
(2) Turn ON your phone's / tablet's Bluetooth and then launch the Hiby Music App
Click ON The Hiby Icon which is 4th Icon at the Top. Click the Hiby Link Client. Do not turn Hiby LInk server because DP3 is the server here. DP3 will show up at the available device list. Click on SMSL DP3 to initiate the connection. This is only for the first time, after that it will auto connect.
(3) If the connection is successful, then click the music icon -> click the folder and below screen will appear.
Here 'a' is the 64 GB Micro SD card and 'c' is the 2TB HDD - Size is not accurate but don't worry, it will work just fine.
(4) Clicking 'c' will reveal the next screen - And here it shows Hiby is playing
--------------------------End of the procedure --------------------
Below I'm browsing my drive and navigate through the folders.
